Preventing White Seams In Dark Paper
Old 11-30-2017, 04:51 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,412
Just hung a room of dark paper, all went well but the next day one or two seams slightly opened up and exposed a white edge, with the dark paper that slight edge shows right up.
Any suggestions on how to prevent this? I have wondered if hanging in a certain direction has any effect?
Ohio painter is offline
Old 11-30-2017, 06:52 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
Re: Preventing White Seams In Dark Paper
How thick was the paper? Double cut the seems?
Sent from my SM-T310 using Tapatalk
overanalyze is offline
SmallTownGuy (11-30-2017)
Old 11-30-2017, 07:09 PM   #3
Mordekyle's Avatar
Rewards Points: 3,300
A Sharpie stripe where the seams will be.
Mordekyle is offline
Old 11-30-2017, 07:57 PM   #4
Always Learning
Rewards Points: 900
When I double cut I will hold my blade at a slight angle. Because of the angle the top piece of paper is cut slightly larger than the piece below. This gives the seem edge a bit of "tension" when you put the seem together. Make sense?
Also I have had luck using dark pencil lead to color a white edge. I know a hanger that keeps some artist charcoal with him and he will lightly rub the edges after he cuts before rolling his seems to help blend darker print.
Bear in mind my experience is 100% with commercial paper and not thinner residential paper.
Old 12-01-2017, 05:40 AM   #5
Wthe paper is good quality residential paper but nowhere as thick as commercial paper. The problem I see with double cutting the seams is that it is not a random match so the pattern will not match up.
I too have tried the chalk to disguise the white seam but I want to know what I can do to prevent it. Thanks everyone.
Old 12-01-2017, 08:35 AM   #6
Always Learning
Rewards Points: 900
If you match the pattern as you install yhe next piece ,before you cut, why wouldn't it match? Does the paper not have bleed over?
Old 12-01-2017, 06:56 PM   #7
30 year novice
carzie's Avatar
Trade: Painting contractor
Rewards Points: 2,057
I always call the manufacturer prior to hanging to get the specifics on hanging that paper. The instructions included can be generic, I've had included instructions that tell you go straight to the wall after wetting and some that say book for several minutes and they're opposite to what I'm told. Same rings true for pre and un pasted papers.
carzie is offline
The Following User Says Thank You to carzie For This Useful Post:
Ohio painter (12-01-2017)
Old 01-29-2018, 07:20 PM   #8
kentdalimp's Avatar
Rewards Points: 82
One trick I have used in the past when environmental conditions are uncontrollable: Match the color to a paint, layout the room, and roll the paint on where the seams go the day before. That way if you get a seam popping, it doesn't jump off the wall.
This is not an excuse to half-@$$ a job, but it has saved a few jobs by not highlighting issues that I have no control over.
Check out the Blog: http://constructioncareerpodcast.com
kentdalimp is offline
The Following 2 Users Say Thank You to kentdalimp For This Useful Post:
Ohio painter (01-29-2018), r a s (01-30-2018)
Old 01-29-2018, 07:48 PM   #9
Kentdalimp, the problem is not wall surface showing through but the edge of the paper showing. In this particular situation I mixed some paint to the paper color and using a tiny artist brush I just colored the edge of the paper that was showing. Problem solved. I read somewhere about hanging paper in a certain direction to prevent this.
The Following User Says Thank You to Ohio painter For This Useful Post:
r a s (01-30-2018)
Old 01-30-2018, 02:38 PM   #10
kentdalimp's Avatar
Rewards Points: 82
Gotcha... Yeah there isn't much you can do because it can be a few things that cause it. There is a decent write up I will link to although it is kind of hard to follow. Know that the edges could have been cut wrong by the factory, but painting it is likely the only way you are going to fix it!
http://www.curlydecorating.co.uk/how...ark-wallpaper/
The Following User Says Thank You to kentdalimp For This Useful Post:
Ohio painter (01-30-2018)
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Screw gun keeps tearing paper on tapered side??? Spencer Drywall 13 02-20-2013 09:11 AM
Turkey Time - White or Dark? Mike Finley Off Topic (Non Trade) 11 11-22-2007 08:22 AM
White over dark blue painted trim Will Painting & Finish Work 10 09-07-2007 10:56 PM
