Painting Over Paper
Old 04-02-2007, 09:24 PM   #1
GWHRsuperhero's Avatar
Trade: painter, roofer
Painting Over Paper
Something Ive never done Ive always stripped it. What do u do when your facing a room were the paper was already painted over? Do you have to strip all the paper with and the paint? If so what do you use? In the past Ive used DIF to strip wallpaper but I dunno what to do if I got a coat of paint over it.
GWHRsuperhero is offline
Old 04-02-2007, 09:26 PM   #2
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
Re: Painting Over Paper
If it is in good shape i just paint over it...but i always tell the customer the problems that might occur in the future.
lornmastro is offline
Old 04-03-2007, 07:02 AM   #3
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
http://www.wallpaperinstaller.com/wa...stripping.html
chris n is offline
Old 04-03-2007, 08:25 AM   #4
What are the problems that could occur in the future? Its already got some bad peeling. Can I use spackle on top of the paper and paint?
Old 04-03-2007, 11:23 AM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
Problems like bad peeling...oh wait, you've got that already
OK, more bad peeling
Sure, if you don't mind more bad peeling
Questions:
Can it still be removed?
You'd be surprised how much painted wallcoverings can be
If not
Exactly how well/badly is it adhering?
Signature Quote
slickshift is offline
Old 04-03-2007, 07:36 PM   #6
If not
Its peeling bad in a few areas because of water damage. Ill proally have to replace some drywall and patch. Overall it looks like it adheres well to the wall. If its already adhering to the wall do i have to worry about new putty and paint causing imediate bubbling? Will the dif or whtv your using soak through the paint to remove the paper?
Old 04-04-2007, 07:02 AM   #7
chris n's Avatar
If its already adhering to the wall do i have to worry about new putty and paint causing imediate bubbling? Will the dif or whtv your using soak through the paint to remove the paper?[/QUOTE]
Yes and Yes,if you use a paper tiger as the link I supplied says.
Just remove the paper,it's the right thing to do.
chris n is offline
Old 04-04-2007, 09:02 AM   #8
Just remove the paper,it's the right thing to do.[/quote]
Ive used that paper tiger before on normal paper. U sure thats gonna be enough for the dif to soak through the paint and then paper?
Old 04-04-2007, 04:58 PM   #9
...jammin
slickshift's Avatar
It depends
You should try it
You might be surprised
Sometimes a coat of paint helps removal
Sometimes a coat of paint is applied to help removal
I you not
Signature Quote
Old 04-05-2007, 06:40 AM   #10
chris n's Avatar
You should try it YES
You might be surprised YES
Sometimes a coat of paint helps removal YES
Sometimes a coat of paint is applied to help removal YES
I you not YES
chris n is offline
How profitable is your painting business? SeanATL Painting & Finish Work 13 04-21-2007 11:16 PM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
