#21 | |
Paint Pro/Faux Artisan
Trade: Painting Contractor/Faux Finisher
Re: Glue On WallQuote:
Thanks, Bay Area Painting Company |
#22 |
turning houses into homes
Trade: Wallcovering Installation
Re: Glue On Wall
I suggest you test the 1-2-3 & Gardz mix "at home" first. PWG and I have been hearing of this mix (and others) from a cohort in NJ. I just tried some in a home project and I am not getting the bonding I hoped for. It has failed the "X" test in a few areas, even on raw rock (yes, THOROUGHLY dusted with a damp miftie)
My jury went back for further deliberations and 9 are pushing for a conviction and execution of this mix. (DAMN, starting to sound more and more like Jack "Don't mix products!" Ford every day)
Wallcovering Installations by Bill Archibald|paperhanger|Eastern Mass|Greater Boston Area|Dover|Wellesley|Franklin|Sharon|MA Last edited by daArch; 07-07-2007 at 11:01 PM. |
#23 | |
Trade: wallcovering installation and painting
of the adhesives as possible if that is what you want to do, using an electric sander with 100 grit sandpaper should suffice, wipe walls down good and then seal with Guardz. I would do my skimming, sanding before applying Guardz. You should not have to prime after applying Guardz. |
#24 |
Tech Geek
Trade: Property Management/Facilities Manager
Re: Glue On Wall
2 year old thread.
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| Backyard office, retaining, and privacy wall | Team Scream | Masonry | 8 | 08-02-2007 11:27 PM |
| moving centennial wall | stacker | Masonry | 4 | 10-20-2006 12:12 AM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
