Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 01-05-2006, 06:46 PM   #1
Tom Rohland's Avatar
Trade: Painting & Pressure Cleaning
Commercial Grade Wallpaper Steamer
I need a commercial grade wallpaper steamer. Home Depot and Lowe's only carry the "Harry the Homeowner" model.
Any suggestion's on where I can find one would be appreciated.
Thanks in advance.
Ranger Painting & Pressure Cleaning, Inc.
Tom Rohland is offline   Reply With Quote
Old 01-05-2006, 07:00 PM   #2
Teetorbilt's Avatar
How big do you want?
I just hose the walls with a garden sprayer set on fine and keep them damp.
IMHO DIF makes no dif. Heat doesn't either, how long does that heat last once it hits the walls?
Wet takes off paper. I take it off in the same way that it went up, in full sheets (most of the time). Mylars and vinyls need to be peeled first.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 01-05-2006, 07:23 PM   #3
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
What do you mean by 'commercial grade'?
If you are talking commercial vinyl, no steamer necessary, just pull it down.
If you are talking just a professional grade steamer for residential goods, don't waste your money. All the companies that I know of that do removal only won't even mess with them. 12"-18" sq in. ain't enough area to work on at a time, plus it eats drywall and ruins woodwork. As Teetor said, a garden pump sprayer is the only way to go. Over protect the floors and soak, soak, soak some more.
ProWallGuy is offline   Reply With Quote
Old 01-06-2006, 04:17 AM   #4
Thanks much to both of you for your rapid reply.
Customer has notified me that he has changed his mind and wants to keep the paper.
Whew!
But then again I was looking forward to that T & M rate!!!!!!!!
Well, back to what I do best.
Thanks again.
Pricing out hanging wallpaper gary lee Wallpaper 51 10-28-2009 06:16 PM
wallpaper removal lornmastro Painting & Finish Work 28 11-25-2008 08:55 PM
Do you own a commercial building/land? MKamis General Discussion 9 05-06-2007 08:14 PM
wallpaper removal question rocco Wallpaper 3 01-30-2006 03:19 PM
Wallpaper steamer? Humble Abode Painting & Finish Work 4 07-08-2005 10:57 PM
