Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 01-04-2009, 03:23 PM   #1
Trade: Painting & Wallpaper
Can anyone help ??
Can anyone tell me the name of wall sizing that puts a fine texture on the wall that feels like fine sandpaper and where I might fine it. thanks
wildwings is offline   Reply With Quote
Old 01-04-2009, 04:03 PM   #2
Sean
SLSTech's Avatar
Is this what you are looking for
http://www.dryvit.com/fileshare/doc/...tion/ds477.pdf
Edit:
By the way welcome to CT
You might want to post an Introduction in the appropriate area & put your location in your profile
SLSTech is offline   Reply With Quote
Old 01-05-2009, 01:34 PM   #3
premierpainter's Avatar
Trade: Painting Contractor
Shields? Proffesional R-30? you are talking about sizing for wall paper right?
premierpainter is offline   Reply With Quote
Old 01-07-2009, 08:04 AM   #4
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Swing Prep Coat leaves a slightly sandpaper-like feel to the wall when applied.
ProWallGuy is offline   Reply With Quote
Old 01-08-2009, 03:06 PM   #5
A bit abrasive.
WisePainter's Avatar
Shark grip silica sand added to your favorite sizing primer.
I use that for my Venetian plaster, and Marmorino finishes as a scratch coat.
My advice: Hire a real painter to do it.
WisePainter is offline   Reply With Quote
Old 01-08-2009, 03:14 PM   #6
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
Sand the Drywall.
Prime walls quickly with out wiping down walls make sure the dust from the sanding is being kicked up by your helper as much as possible while you are spraying
will give you a nice gritty texture on walls
rbsremodeling is offline   Reply With Quote
Old 01-08-2009, 03:42 PM   #7
A bit abrasive.
Originally Posted by rbsremodeling View Post
Sand the Drywall.
Old 01-23-2009, 01:35 AM   #8
Nigel S. Shorts's Avatar
Trade: Wallpaper Whisperer
Well, since this is in the wallpaper thread I'm going way out on a limb and assume he's papering after sizing. And by the way, this isn't sizing, but prep coating, to pick a nit. sizing is a thinned adhesive rolled on the wall to promote adhesion.
Anyway, Swing paints ltd. out of Montreal has been making the best wall prep system for decades. It called, appropriately enough, Wallpaper Prep Coat, or just Prep Coat for short. It's virtually clear, showing a slight greenish- blue tint that is just enough to see where you've been with the roller or brush.
Prep coat is an interesting product. It adheres to glossy surfaces so that you can paper over the in as quick as 15 minutes (I'd avoid doing it that soon, though). If you splatter it on semi gloss woodwork, or marble counter tops, it will scratch off clean after wetting it slightly. Yet it is hands down the best surface to install wallpaper over, providing the necessary tooth to give a great bond between paper and wall.
http://www.swingpaints.com/3107.htm
The only downside is good luck getting this product. It's difficult, so maybe email them and see who's carrying it near you, if anyone.
Nigel S. Shorts is offline   Reply With Quote
Old 01-30-2009, 09:28 PM   #9
BAMAHANGER
Trade: wallcovering installer
dont want any grit behind my paper
jhall is offline   Reply With Quote
