Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Wallpaper
Old 08-10-2006, 07:38 AM   #1
Trade: painter
alkyd primer or not
Hello,
I am in the process of removing wallpaper (this is a first for me) from a room in a basement. I will skim coat the wall to even out the surface after removal of the paper. The wallpaper hanger requested that I use ALKYD PRIMER for the walls to prepare for new wallpaper.
Do I really need to use an alkyd primer?
Since this is in a basement with not a lot of ventilation, I'm wondering how important it is to use alkyd primer instead of a water based primer?
Thanks
cowtown is offline   Reply With Quote
Old 08-10-2006, 10:16 AM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Not sure why the hanger wants an alkyd. Back in the day before the VOC laws changed the formulation of oils, it was nice to hang over. But not anymore. The alkyd primers don't tend to dry as hard as they used too. So, I don't hang over alkyd anymore. But, if the hanger requested it, do it, and put the liability of his paper job in his lap, not yours.
ProWallGuy is offline   Reply With Quote
Old 08-10-2006, 05:59 PM   #3
My custom title
Brushslingers's Avatar
I'll defer to dude.. he's famous ya know.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 08-10-2006, 06:17 PM   #4
MODERATOR
ProWallGuy's Avatar
C'mon now, I'm not the dude, I'm the guy.
Old 08-10-2006, 06:28 PM   #5
Trade: painter
Thanks Pro Wall Guy.
This job is turning into a real nightmare, no primer or paint on drywall so it's tearing up the drywall paper in some areas as I peel away the wallpaper. It's slow going but the h.o. and I guess the paper hanger wanted the wallpaper off. The guy I'm working with has been skim coating the walls but he may end up doing 3 coats of mud to build up areas where the drywall paper was tearing.
Anyone with suggestions on how to treat drywall that has large areas of torn paper? Problem is it tends to bubble if you coat mud over these areas.
Old 08-10-2006, 06:34 PM   #6
MODERATOR
ProWallGuy's Avatar
Simple fix. After removing the w/c, apply a coat of GARDZ. This will eliminate the bubbling, and making the skim coat go easy as pie.
Old 08-10-2006, 11:23 PM   #7
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
I would have thought you would have suggested Gardz for the whole job...
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline   Reply With Quote
Old 08-10-2006, 11:25 PM   #8
MODERATOR
ProWallGuy's Avatar
Personally, I would have. I love to hang over Gardz. But it ain't my job, and the hanger asked for oil.............
Old 08-10-2006, 11:46 PM   #9
Painting Contractor
Use Gardz and don't tell him, then listen to him rave about how well it went
The NAPP
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Tinting primer question icfbunt Painting & Finish Work 5 12-12-2006 06:44 PM
SW A100 Alkyd Primer Double-A Painting & Finish Work 24 10-03-2006 01:38 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 04:35 PM
