Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Faux Finishes
Old 07-13-2009, 04:54 PM   #1
using venetian plaster in bathrooms
I used home depot venetian plaster in a bathroom and i burnished it after but after a month or so it cracked and chipped and dulled alot. and i heard you could use a wax after that would protect it but i cant find a product. Does anyone know if there is a wax and what type you could use or have any suggestions????
gno30 is offline   Reply With Quote
Old 07-13-2009, 05:31 PM   #2
Estimator
DavidNTX's Avatar
Trade: Estimating
A company called Triarch Industries (Duroplex) has some waxes that are supposed to be pretty rugged. I haven't dealt with them in years but I'm sure they are still around. You used to have to be licensed/certified by them to install their products. I'm sure if they are still around and still have a wax it would probably work. They have their own venetian plaster.
http://www.triarchinc.com/products.asp
DavidNTX is offline   Reply With Quote
Old 07-13-2009, 06:14 PM   #3
Trade: Ornamental Plasterer/Restorer
There are few types of wax for plaster. One is oil based wax, brand name "Baldini", other is water base liquid was - 'ecoCera'. Or you can use natural bees wax. Cook bees wax, put a little turpentine and californium, grease plaster with hot wax and buff.
Resta is offline   Reply With Quote
Old 07-13-2009, 09:51 PM   #4
LAD
Dan-Liquid Art Design
Trade: Decorative Finisher
What was the cause of the cracking? Other than the 'cheap' factor of the product? Applied too thick?
Anyway, in the future, a higher quality VP will alleviate the need for any topcoat. Or use a lime putty plaster which is water,mildew, and stain resistant. Try Liberon furniture wax in neutral. (solvent based) Wears like iron, polishes to a mirror sheen. You can also use a natural soap, beeswax (which you can buy ready to apply), or waterborne waxes. Your faux/decorative finish suppliers will have quite a variety of these products, though you should be able to find Liberon quite easily.
www.LiquidArtDesign.com
LAD is offline   Reply With Quote
Old 07-17-2009, 08:10 PM   #5
DRC
Trade: painting
If its a high use bathroom the plaster is going to fail from the high humidity.
DRC is offline   Reply With Quote
Old 09-06-2009, 06:36 PM   #6
www.DPAP.org
Trade: decorative painting
For Home Depot Venetian plaster in bathrooms, I use Butcher's Bowling Alley wax sold by HD also.
BAForese is offline   Reply With Quote
Old 11-20-2009, 01:11 PM   #7
Trade: Fine Wall Finish Application
What was on the walls before you applied the paster?
Plaster Ayn is offline   Reply With Quote
Old brick & mortar pond with plaster coating, need help kjac3585 Masonry 2 08-12-2009 06:02 PM
Drywall over plaster ceiling? RandyB1986 Drywall 27 06-22-2009 04:35 PM
Question about patching plaster Dorman Painting Painting & Finish Work 4 02-09-2009 10:49 PM
Plaster applied to interior of interior wall problems CMU General Discussion 1 10-14-2008 09:37 AM
Venetian Plaster ??? CreativePainter Painting & Finish Work 7 06-16-2007 06:06 AM
