Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Faux Finishes
Old 07-05-2009, 09:44 PM   #1
genecarp's Avatar
Tobius stucco, Quick revue
Been applying this product the last few days. Purchased through Green Depot. My application is over new sheetrock, however many different substrates will accept this product with different levels of prep. For new sheetrock primed surface is required, color tinting the primer is an option. This product is very easy to work with, about 20 standard colors available. I applied with a metal trowel, first coat went on with an 8'' knife, because of the barrel cieling the first coat with the 8'' knife could only run in one direction (with the curve). Day two final coat was applied with a 6'' knife in a hatch pattern. After 5 minutes the second coat was knocked down with a 10'' knife, again following the curve. Also, the first coat went on with a tight trowel technique 1/16th" thick. The second coat went on a bit heavier 3/16th max. Here are some photos of the technique i used, the interesting thing about this product is the number of finish options that can be achieved based on different techniques. If you would like more detail or photos, just ask. G
http://
genecarp is offline   Reply With Quote
Old 07-05-2009, 09:46 PM   #2
genecarp's Avatar
http://
Old 07-05-2009, 09:47 PM   #3
genecarp's Avatar
First coat
http://
Old 07-05-2009, 09:49 PM   #4
genecarp's Avatar
Seam between first and second coat (wet edge)http://
Old 07-05-2009, 09:50 PM   #5
genecarp's Avatar
Final finish, still a bit wet
http://
Old 07-05-2009, 09:51 PM   #6
genecarp's Avatar
Here are some other colors, you can blend working with 2 mechanics
http://
Old 07-05-2009, 09:53 PM   #7
genecarp's Avatar
http://
Old 07-05-2009, 10:20 PM   #8
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Repair, and Paint.
We have used this product on several jobs. I've alway's been pleased with the results. Thanks for the revue, And nice work Gene.
Here's the link to their site------->Tobias Stucco
www.PeckDrywall.com -------- www.PeckPainting.com -------- My Blog
My-Facebook
Sir Mixalot is offline   Reply With Quote
The Following User Says Thank You to Sir Mixalot For This Useful Post:
genecarp (07-05-2009)
stucco vs dry-vit niteliters Masonry 0 06-24-2009 12:04 PM
Stucco patch NAV Masonry 9 05-26-2009 02:41 PM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 07:25 AM
Stucco Brick repair jas179 Masonry 6 10-19-2008 06:34 AM
1 coat vs. 3 coat stucco finishing janrickey General Discussion 9 08-16-2008 06:53 PM
