Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Faux Finishes
Old 04-22-2009, 08:54 PM   #1
Removing Suede Faux Finish
Hey guys,
I am finishing a basement that used to have RL suede finish on it. I did not do anything to 2 of the walls and they still have the suede finish on them. my client does not want the suede finish any longer. Any quick tips on how to eliminate this? Can it be painted over? thanks
jeff
jmarcin is offline   Reply With Quote
Old 04-22-2009, 09:08 PM   #2
Nepster
Trade: general contracting
You might be able to get away with using a high build primer over it and then your new finish coat. If you use flat paint it may hide some of the sued that is still present.
antnepi is offline   Reply With Quote
Old 04-22-2009, 09:11 PM   #3
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
There is no paint that will smooth this out, you will need to sand lightly and then skim out the walls, then prime and re skim spots and then paint the walls.
Mr. Mike is offline   Reply With Quote
Old 04-22-2009, 09:16 PM   #4
Nepster
Mr. Mike is right. It may be hard to sell that to the HO because it is going to be expensive, but that is really the only way to get rid of it completely.
Old 04-22-2009, 09:27 PM   #5
Organic Painter
Mr. Mike's Avatar
Where are you located at? what state Jmarcin?
Old 04-23-2009, 09:40 AM   #6
Trade: Prep Nazi
I would knock it down with a variable speed orbital sander first, then skim as Mike described above. Anything to make it a little easier to skim coat.
www.sccustompainting.com
StefanC is offline   Reply With Quote
Old 04-24-2009, 07:29 AM   #7
LAD
Dan-Liquid Art Design
Trade: Decorative Finisher
Here's a different angle: Upsell the customer on a new and better faux finish (perhaps using a light texture) and go right over it. Or if you don't do faux, sub it out and take a juicy referral fee.
A.B.C. people! (Always Be Closing)
www.LiquidArtDesign.com
LAD is offline   Reply With Quote
Old 04-24-2009, 10:05 AM   #8
Organic Painter
Mr. Mike's Avatar
That's what I preach,
Old 09-18-2009, 10:42 PM   #9
I have no personal experience, but after calling Glidden with this exact same issue they recommended i just paint over the suede finish. Its not a very agressive texture so i can't see it being too much of an isue.
Duckwarrior is offline   Reply With Quote
Painting over a faux finish pitterpat Faux Finishes 4 10-01-2008 02:08 PM
faux finish on oil based cabinets lornmastro Faux Finishes 1 06-27-2007 12:19 AM
faux finish and venitian sterling stone Painting & Finish Work 3 02-15-2007 09:29 AM
Cost of Faux Finish AFT Painting & Finish Work 6 01-20-2007 11:45 PM
