Painting Over A Faux Finish
Old 06-21-2008, 08:48 PM   #1
pitterpat's Avatar
Trade: HandyWOMAN
I have a bedroom in my house that has one wall with a feather painted faux finish on it. I want to repaint the entire room. Do I need to sand the faux finish wall first before I prime it or will it just be ok to prime over the faux finish. There is only one coat of glaze in the faux finish.
Thanks, Pat
Pat Harris
A HandyWOMAN Service, LLC
"Why call a handyman when you can call A HandyWOMAN?
pitterpat is offline
Old 06-21-2008, 09:10 PM   #2
Teetorbilt's Avatar
Re: Painting Over A Faux Finish
Going back with latex? Personally, I'd go over it with an orbital. 80# to start and 150# before primer.
Sanding up close allows you to see all of the minor imperfections and correct them prior to painting, not real critical when dealing with light/flat colors. Darks and glosses will show a fly tur*.
Albert Einstein
Teetorbilt is offline
Old 06-21-2008, 09:21 PM   #3
pitterpat's Avatar
Trade: HandyWOMAN
Thanks Tetor,
How about sanding with a drywall pole sander?
Pat Harris
Old 06-21-2008, 10:36 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
If the faux is a pos/neg (add/sub) glaze using a feather, the chances are huge it will show through the primer and top coats (texture-wise)
A pole sanding won't cut it
It really needs a bit of the ol' orbital there
I also would not mess around and probably hit it with 80 first
Signature Quote
slickshift is offline
Old 10-01-2008, 03:08 PM   #5
Dmax Consulting
Dmax Consulting's Avatar
Trade: Paint Contractor
What is "feather painted faux finish?"
Dmax Consulting is offline
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
Faux Wall Finish (marble) b34nz Painting & Finish Work Picture Post 1 09-05-2007 01:05 PM
faux finish on oil based cabinets lornmastro Faux Finishes 1 06-27-2007 01:19 AM
faux finish and venitian sterling stone Painting & Finish Work 3 02-15-2007 09:29 AM
Cost of Faux Finish AFT Painting & Finish Work 6 01-20-2007 11:45 PM
