Drywall1
Guest
Posts: n/a
Interior Wall Faux Finishes
I'm mainly a drywall/exterior stucco guy. Doing a whole house stucco job right now and customer wants an interior "stucco like" finish on a few walls. Can any of you point me in the direction of a product that you have worked with or have seen. TIA
Nate |
thom
Guest
Posts: n/a
Re: Interior Wall Faux Finishes
We do a brocade texture on ceilings that looks similar to a skip trowel finish on stucco (without the roughness of the sand), or there are products that are paint additives that give paint a sand texture that's similar to a sand finish on stucco.
Drywall1
Guest
Posts: n/a
Not quite what I'm looking for but thanks. Looking for a product troweled on...but not drywall mud.
Exroadog
Guest
Posts: n/a
Murs D art by Safra. (School of Italian Plasters) Interior only
Aquastone by Aqua Finishes. Interior and Exterior |
dincao
Guest
Posts: n/a
Versiplast by B.G.I can be trowled on for a fine or heavy texture...
kbdesigns
Guest
Posts: n/a
Sometime try Tobias Stucco. Very nice product that can be troweled on it many different ways.
kenscar
Guest
Posts: n/a
Why not just use drywall mud? If it's the drying time - use 20 minute powder.
FoilEffects
Guest
Posts: n/a
If all she is going to do is paint it just use JC, I have done 100's of thousands of sf of it under paint and finishes and it is great. Here is my little mix for added strength.
4.5 gallon bucket JC 1 tube quality caulk 1 qt of ProBlock primer 1/2 qt water Works great and has for many years for me. |
#9 | |
genecarp
Guest
Posts: n/a
Re: Interior Wall Faux FinishesQuote:
JBBS
Guest
Posts: n/a
Dryvit!
qdslse
Guest
Posts: n/a
I'd go with the Versiplast, will not chip and will hold tight. Have done it dozens of times. Afterward you can paint and colorwash, or just colorwash, depending on the look the client wants. You can get Versiplast from Chicago Institute of Fine Finishes at fauxbykathy.com It is awesome stuff, you can work it down to a suede or build it up with layers to a deep texture, the choice is yours......
Here's a couple of pics |
Dmax Consulting
Guest
Posts: n/a
I like foil's recipe
LocalSoljah
Guest
Posts: n/a
What I do quite a bit is is use interior basecoat such as Kal-base. Then for finish i use exterior finish. You can use any of the synthetic sand finishes or a swirl or worm track finish and the final product is absolutely beautiful.
| charging for faux finishes | Humble Abode | Faux Finishes | 45 | 04-11-2009 06:59 AM |
| Faux Wall Finish (marble) | b34nz | Painting & Finish Work Picture Post | 1 | 09-05-2007 01:05 PM |
| faux finish on oil based cabinets | lornmastro | Faux Finishes | 1 | 06-27-2007 01:19 AM |
| faux finish and venitian | sterling stone | Painting & Finish Work | 3 | 02-15-2007 09:29 AM |
| Reasonably Priced Faux Marble Columns | slickshift | Painting & Finish Work | 8 | 09-07-2006 09:21 PM |
