Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling
Closed Thread
Old 05-13-2009, 02:26 PM   #1
Trade: home renovations
window return in concrete block house
I removed the drywall/plaster in my house that is under renovations. Unfortunately the inside of the window returns did not come very clean. I'm not sure what is the best way to finish the inside of the window returns which were previously plaster. There doesn't seem to be enough room to put a furring strip on the block and then drywall, since the window frame is very shallow. The surface of the remaining block is very rough so attaching the drywall directly to the block would not work.
Can I put drywall compound directly on the block to smooth it out, eventually building enough up to cover the buck strips hold the window to the block.
Any suggestion would be greatly appreciated.
bmancanfly is offline
Old 05-13-2009, 02:32 PM   #2
Trade: Remodeling general
I smell HO here but my wife told me to be nice to two people each day.
are the window jambs made of wood or what kind of window are they.
naptown CR is offline
Old 05-13-2009, 03:48 PM   #3
Questions are:
Steel or aluminum?
What do you really do for a living?
For naptown:
Why do you only listen to your
wife when she's wrong?
neolitic is offline
Old 05-13-2009, 04:06 PM   #4
Well you'd both be wrong in your assumptions. But that really doesn't pertain to my question.
But just for the record, I renovate houses for a living - and have done so for the last 11 years. I type this from my current home which I built myself - completely. I poured the foundation, did the framing, sheathing, siding, plumbing, electrical, roof, windows, ALL myself. And when I say I did it myself I don't mean I contracted someone else to do it, or ordered around some Mexican to do it for me, I did it with my own two hands. And the answer to your next question is.......YES, I do have a license.
This however is my first concrete block house, in FL, and has presented some challenges I haven't encountered before.
Now if I've passed the hazing requirements for this forum, if either of you, or anyone could answer my question I'd appreciate it.
Aluminum windows, but that could be changed.
Old 05-13-2009, 04:37 PM   #5
I wonder what could have led us
in that direction?
I removed the drywall/plaster in my house that is under renovations. .........
Maybe if you had led off with
a bit more information......
No hazing, clarification and qualification.
A tad less attitude might encourage
more helpfulness too.
Not wrong with all my assumptions.
DuraBond or similar setting compound
would be a better choice than drywall mud.
Though it wouldn't be a good idea here,
it might work well in Fla.
neolitic is offline
Old 05-13-2009, 06:50 PM   #6
Teetorbilt's Avatar
Drywall to block would be a bad idea. You don't say how much room you have to play with or if you have sills (some of the older homes didn't).
If you had or can accomodate sills, set them first.
Options for the returns include Hardieboard, about 5/16", installed backwards. Mud in with unsanded stucco if you're good, setting drywall if you're not.
Wire lath, about 1/4". Use brown stucco to bond to the concrete and then finish with the white or go back to the setting compound to finish.
There are a few other options. I just got home from my second week on a flooring job, (whole house) and am a little burned out. I'll keep track of the post IF you reply.
In defense of the previous posters; This is a contractor's site and the majority of the members work hard to keep it that way. In FL anybody that owns property can act as a Homeowner Contractor and are allowed to build their own homes. That walks a line that that I need to look into.
Albert Einstein
Teetorbilt is offline
Old 05-13-2009, 07:15 PM   #7
For naptown:
Well there several reasons
1- she is a trial lawyer and a pro at it, arguing is futile.
2- She has two rules 1 she is alwas right 2 if she is wrong refer to rule 1
3- She puts up with my spending an inordinate amount of time here.
4-I am P whipped
Old 05-13-2009, 07:20 PM   #8
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
If you built the house and did all that, why are you confused over the window returns, you did them in the first place right?
Teetor is pretty dead on. There are some other options, it depends on what style you like.
I also have a drivers license.
WarnerConstInc. is offline
Old 05-14-2009, 09:11 AM   #9
thanks teetorbilt.
Some of the windows have sills some are already removed.
I explored the lathe and brown stucco option but I was trying to avoid having to do a lot of mechanical fastening of lathe to the block on the returns. Plus I have no experience with stucco.
I like the idea of the backer board but some of the returns are so irregular and un-smooth that it would be difficult to get them to lay anywhere close to flat.
Old 05-14-2009, 11:21 PM   #10
cleveman's Avatar
Trade: custom home building
Why don't you use some marble pieces or just tile? Thinset them on to the block.
cleveman is offline
Old 05-15-2009, 03:30 AM   #11
joasis's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is online now
Closed Thread
Best way to fasten plywood forms to concrete block? sk071077 Construction 16 03-10-2009 12:46 AM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
adding 2nd story to block house 72chevy4x4 Construction 3 01-21-2007 09:20 PM
Concrete block brickledge on ICF stemwall gregj Masonry 3 09-29-2006 09:07 AM
