Window Jamb & Sill Material?
Old 07-28-2013, 11:56 PM   #21
Tony R's Avatar
Trade: Windows and Doors
Re: Window Jamb & Sill Material?
primed pine for stools and aprons, clear pine for same if staining
Tony R is offline
Old 07-29-2013, 06:08 PM   #22
ArtisanRemod's Avatar
Rewards Points: 582
Take this for what it's worth, but I barely have to sand MDF edges cut with my TS55 Festool track saw. Perfect cuts every time.
ArtisanRemod is offline
Old 07-31-2013, 08:14 AM   #23
Kitchen Customizer
ryanshull's Avatar
Trade: Interior Remodeling
Rewards Points: 310
I've always used clear pine, even when painting. MDF is for Walmart furniture lmo.
ryanshull is offline
Old 07-31-2013, 08:24 AM   #24
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
I never use pine or mdf. I rarely use poplar, most times my paint grade lumber is soft maple.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 01-05-2017, 04:47 PM   #25
alby's Avatar
Trade: Drywall
Rewards Points: 4
Do you also use Azek for bathroom windows?
I'm thinking there would be more issues where tile is present
alby is offline
Old 01-05-2017, 07:12 PM   #26
Dirtywhiteboy's Avatar
Rewards Points: 7,966
I like PVC in the shower- bathroom and caulk in with sillycon.
Dirtywhiteboy is offline
Old 01-05-2017, 08:45 PM   #27
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
PVC is fine in a shower. I wouldn't caulk it with silicone, though.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
slowsol (01-05-2017)
Old 01-05-2017, 10:44 PM   #28
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 768
What do you use to caulk that? Have always used bathroom silicone, but is there something better.
Sent from my LG-V520 using Tapatalk
Randy Bush is online now
Old 01-05-2017, 10:47 PM   #29
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 556
We personally use OSI Quad when caulking PVC.
Xtrememtnbiker is offline
Old 01-05-2017, 10:52 PM   #30
alby's Avatar
Trade: Drywall
Rewards Points: 4
PVC for window trim is good.
But what about for the jamb that holds the window?
Every time I replace a window, I find that the jambs take a serious beating from the elements.
PVC might be an option but I'm concerned about seasonal movement, especially for bathrooms that have tile for trim.
I called technical help at Veranda. She said that Veranda is suitable for window jambs citing failure occurs at 225 degrees. But honestly, she sounds like a foreign help desk person from China. I prefer help desk from a tradesman.
alby is offline
Old 01-05-2017, 10:59 PM   #31
tjbnwi's Avatar
Rewards Points: 2,672
OSI precautions against using Quad for interior applications. It is an exterior only product.
http://www.ositough.com/content/dam/...S/quad_tds.pdf
OSI makes H2U for interior applications.
tjbnwi is online now
Old 01-05-2017, 11:05 PM   #32
Randy Bush's Avatar
Rewards Points: 768
I do for exterior work. Just have not for interior stuff.
The Following User Says Thank You to Randy Bush For This Useful Post:
Xtrememtnbiker (01-05-2017)
Old 01-05-2017, 11:13 PM   #33
Rewards Points: 556
I wasn't paying attention to the context... We haven't used Quad inside.
Thanks.
Old 01-05-2017, 11:16 PM   #34
#MAGA
Silicone just doesn't go with PVC. Exterior would be Quad as XMB mentioned. Interior I would use some type of interior rated urethane caulk. Tower Tech is what I use for most caulking applications.
Old 01-06-2017, 08:06 AM   #35
NJ Contractor's Avatar
Trade: General and Electrical Contractor
Rewards Points: 1,652
Originally Posted by WarnerConstInc. View Post
Are you guys using primed and painted pine and poplar for parts that will be exposed to the elements? If so, 4 years tops, before it starts to rot.
Cypress, white oak, and elm are way better choices for exterior wood.
If just on the inside, knock yourself out.
Agreed, we use Azek or Kleer PVC trim outside most of the time. I have replaced a lot of exterior trim after only a few years. After it's painted you can't tell the difference.
NJ Contractor is offline
Leaking window MEL Masonry 33 02-03-2013 08:12 AM
exterior prehung door replace - uneven floor artinall Windows, Siding and Doors 19 12-24-2012 10:38 AM
bow window jamb sizing Wayfarer Doors Windows, Siding and Doors 4 05-15-2012 06:48 AM
