Window Jamb & Sill Material? - Remodeling - Contractor Talk
Old 07-24-2013, 06:31 AM   #1
miillersickness's Avatar
Rewards Points: 85
What do you guys use? I have been using some primed 1x material but the edges have been looking crappy lately, thinking about trying some poplar or MDF.
miillersickness is offline
Old 07-24-2013, 07:17 AM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,238
Re: Window Jamb & Sill Material?
In the past I have used MDF,it is ok but don't like using it for the sill anymore. Stuff don't like water that lays on it . Actually I like primed pine now that I have stared using it, holds nails or staples a lot better when making the jamb boxes.
Poplar or D / clear pine for stained window trim.
Randy Bush is online now
Old 07-24-2013, 10:01 AM   #3
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
We've used AZEK pvc for new jambs with a lot of success. We also use primed poplar with clear pine or poplar inside stools as well. Like Randy says, if they are staining their interior trim casing, then we use pine.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
The Following User Says Thank You to CompleteW&D For This Useful Post:
Trim_Solutions (06-01-2017)
Old 07-24-2013, 11:46 AM   #4
Rewards Points: 85
Only place around me i can seem to find primed pine is home depot, its kind of expensive but i might have to give it a try.
Old 07-24-2013, 12:14 PM   #5
I don't know where you're located in Arkansas.... but surely there is a molding and mill work shop somewhere near you. If they don't already stock it, they can certainly get it for you. And, it'll very likely be of a much better quality and WAY better price than what you're going to find at a box store.
- John Williams
Old 07-24-2013, 12:19 PM   #6
Rewards Points: 85
We have a place in Missouri we buy Alot of 13/16" oak and maple stock from, they might have some poplar i could get cheap enough. Have to drive over an hour both ways though. Just called my local lumber yard and they have 1x6x8 clear pine for about $21 apiece. Anyone think that's high or is it just me?
Old 07-24-2013, 12:55 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 4,704
Are you guys using primed and painted pine and poplar for parts that will be exposed to the elements? If so, 4 years tops, before it starts to rot.
Cypress, white oak, and elm are way better choices for exterior wood.
If just on the inside, knock yourself out.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-24-2013, 12:57 PM   #8
No.... if it's going to be exposed to the weather, we only use PVC or cap with a coil stock. I was only speaking of what's exposed on the inside. I should have clarified that.
Sorry....
- John Williams
Old 07-24-2013, 04:40 PM   #9
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
I've always used Western Red Ceder for exteriors. Never had any issues and it's fairly inexpensive.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
The Following User Says Thank You to Jason Whipple For This Useful Post:
j_sims (07-24-2013)
Old 07-24-2013, 05:28 PM   #10
Randy Bush's Avatar
Sorry....
Pretty much the same for us.
Old 07-24-2013, 06:20 PM   #11
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
if the budget has gotten chewn up on framing and siding then we use mdf sils but if we still have plenty of $$$ in the bag we go with pine or poplar but for the rest of hte jamb its mdf
woodworkbykirk is offline
Old 07-24-2013, 09:05 PM   #12
Rewards Points: 85
Ya sorry i should've clarified, I'm referring to interior trim only. Using MDF how does one go about making their reveal (cut edge) look good? I was thinking apply some drywall mud and sand off.
Old 07-24-2013, 09:24 PM   #13
Texan
j_sims's Avatar
Rewards Points: 68
Or watered down wood glue..too time consuming though.
I usually just sand cut edges with a hand block sander..it gives a good slick edge and closes off the pores.
TEXAS Born, TEXAS Bred, When I Die, I'll be TEXAS Dead
j_sims is offline
Old 07-24-2013, 09:36 PM   #14
Randy Bush's Avatar
When I did use the stuff I would always put the ripped edge to the window.
Old 07-24-2013, 10:03 PM   #15
Rewards Points: 85
Ill try sanding it down and see what happens. I'm honestly considering the clear pine though.
Old 07-24-2013, 10:26 PM   #16
Randy Bush's Avatar
Clear pine gets kind of spendy if it is just getting painted.
Old 07-25-2013, 01:01 AM   #17
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
Sand the saw kerfs and use an epoxy primer if you have a lot. Glue or spackle and primer for one or two.
-Dennis
WarriorWithWood is offline
Old 07-25-2013, 06:26 AM   #18
Rewards Points: 85
Thanks for the advice, think I'll at least try the MDF, its too cheap not to.
Old 07-26-2013, 02:26 PM   #19
Preserving the Past
With MDF, if you sand the edges well,prime, and put two coats of paint on you should be just fine. If it looks like crap after that then you didn't sand it well enough... (or you use cheap paint)
Facebook | Twitter
Old 07-26-2013, 09:38 PM   #20
Rewards Points: 85
Great advice, i plan on sanding then applying some stix bonding primer then 2 coats SW solo
Leaking window MEL Masonry 33 02-03-2013 09:12 AM
exterior prehung door replace - uneven floor artinall Windows, Siding and Doors 19 12-24-2012 11:38 AM
bow window jamb sizing Wayfarer Doors Windows, Siding and Doors 4 05-15-2012 06:48 AM
