What Is A Good Black Mold Killer?
Old 05-12-2010, 02:27 PM   #1
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
I am demo-ing a master bath. The tile was set straight onto regular GWB. I have ripped the GWB off and I have some bad wood. I can't remove the studs because the HOs don't want that room disturbed, so I am going to just sister new PT lumber in the cavities.
What are some of the sprays that y'all would recommend that I could use to kill the mold that is there now.
I will be putting Durock on it later this week. Any help is appreciated.
http://www.flickr.com/photos/wallmax...7624048194824/
wallmaxx is offline
Old 05-12-2010, 02:31 PM   #2
Working
Cole82's Avatar
Rewards Points: 2,276
Re: What Is A Good Black Mold Killer?
Dehumidifier and some hydrogen peroxide work well. Used it in my house when it flooded in 08. The local house department told me that bleach kills about 75% of the molds out there, peroxide kills them all though. I did have to do it a couple times where it was bad.
Cole
The boss of awesome
Cole82 is offline
Old 05-12-2010, 02:38 PM   #3
genecarp's Avatar
Rewards Points: 2,000
http://www.amazon.com/Molderizer-Org.../dp/B001ACFV06
GMOD
genecarp is offline
Old 05-12-2010, 02:43 PM   #4
Is your funny looking treated KDAT?
Our YP would want to dry in place
for weeks before closing the wall,
unless it was KDAT.
neolitic is offline
Old 05-12-2010, 03:32 PM   #5
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Originally Posted by genecarp View Post
Thanks for the quick replies. I went to lunch and had the CT braintrust work my problem. That is too cool.
It seems to be unavailable right now.
wallmaxx is offline
Old 05-12-2010, 03:34 PM   #6
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Available elsewhere:
http://www.mycleaningproducts.com/mold-removal/
Angus
angus242 is offline
Old 05-12-2010, 03:38 PM   #7
CAD Services
wallmaxx's Avatar
Rewards Points: 144
unless it was KDAT.
You mean our perforated PT hemlock. I think you can get KD stuff for finished decks (and it has no exterior face perforations) but mostly the PT stuff comes pretty wet and "machined" (and fat by an 1/8" in both directions)
wallmaxx is offline
Old 05-12-2010, 03:40 PM   #8
I just worry about covering up
anything that has as much moisture content
as our stuff has.
neolitic is offline
Old 05-12-2010, 03:50 PM   #9
Jaf's Avatar
Trade: Builder
Rewards Points: 250
Why not use bleach, then scrub with TSP?
I think that's the standard solution, unless black mold calls for something special. I've heard that 'starchy mold' is hard to get rid of, whatever that is.
Jaf is offline
Old 05-12-2010, 04:10 PM   #10
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
I use bleach, seems to work good
kenparsonscontracting.com
KennMacMoragh is offline
Old 05-12-2010, 06:52 PM   #11
Dan
ApgarNJ's Avatar
if you really ready up on mold sites, bleach has a lot of water in it and can actually help feed the mold. it may look clean but it will come back. I was reading up on this a while back.
ApgarNJ is offline
Old 05-12-2010, 07:07 PM   #12
Insuranceclaims's Avatar
Trade: Insurance Restoration
Rewards Points: 201
Ok, this is probably more information than you want, but here goes:
Unless you are a hygienist, I would not scare homeowners and tell them that they have Black Toxic Mold. All mold is black when it is wet!
Unless you are qualified and the mold has been tested at a laboratory, mold is mold until told otherwise.
In addition, you are also raising a red flag and could be opening yourself for liability issues.
The key issues in dealing with mold are:
1) Identify the source of lost before attempting any work. Make sure the source is repaired or stopped.
1) Before performing any work, do you need to have testing of the mold performed by a licensed hygienist? Does the insured have any respiratory issues? Are there pets, small children or senior citizens in the house? They are more susceptible to an unclean breathing environment.
A hygienist can identify the type of mold and spore counts in the house compared to outside the house. For additional fees, the hygienist can write a protocol, which tells what and how to remediate the mold. After all remediation is done and before repairs are made, a post-test clearance is also performed. These varied services can run anywhere from $375 to $2,500.
2) Understand the proper method or removal to prevent further damage in the structure.
In your case, it sounds like water seeped through bad grout lines or got into the wall cavity by seeping aoround the fixtures that may not have been properly caulked.
Before making repairs, there are several options: the right way and the wrong way.
Mold grows from the presence of stagnant water or an area with high moisture content, a food source.....wood framing or the paper from drywall, and high temperature (70+)////high relative humidity (60%+), which you would have inside a wall cavity.
Obviously, you have all of these characteristics in the tub/shower.
Containment and proper removal are mandatory.
As soon as mold is detected, I would have detached the door, brought a small air scrubber in the room, contained th door opening with a piece of 6 ml plastic, sealed with duct tape. Then, I would have attached a zipper to get in/out of the containment. The air scrubber would keep the air clean and catch any mold spores floating in the atmosphere, when you remove the tile/GWB.
You or your employees should have on Tyvek suits and cartridge respirators.....al least 1/2 mask or full face mask.
As the materials are removed, all items should have been double bagged in 6 ml plastic and taped. Wipe down the outer bags with Microban before exiting the room.
The purpose is to prevent the mold spores on the material from spreading into other rooms that are not contaminated. If they do travel into other rooms, the spores can float and will eventually land on the walls, floor or contents. Depending on temperature/relative humidity in the house, they can either sit dormant or incubate from the high temperature/high relative humidity and mold will generate from the spores.
Remediation
Now that the wall cavity is exposed, you see the mold growth on the framing. You will want to use a moisture meter to determine what areas of the wall cavity and or framing are wet. You will set up a dehumidifier to dry the structure.
Unless qualified, you may want to outsource this next step: a) hepa vacuum the mold, wipe down with the proper chemicals (Microban, Shockwave), and sand/vacuum at the same time.
While under containment, you may have a dehumidifier and an air scrubber in the room. Once the wall cavity is dried and cleaned, also hepa vacuum and wipe down the entire ceiling and walls, plus all items in the room. Leave the air scrubber in the room an extra day.
Post-Test Clearance
At this point and depending on the degree of mold, you may want to get a post-test clearance. Your containment and air scrubber should still be running. If you fail the test, more cleaning may be required.
Once you pass the test, you can encapsulate the framing. See below.
Visit the site of Fiberlock Technologies:
http://www.fiberlock.com/products/8360.html
You can call at 800-342-3755 and ask for tech support for further help.
Another product is Microban. http://www.prorestoreproducts.com/
Also talk to sales/support: 800-332-6037 or chat online....not sure of their hours.....visit site and try.
In recent years, OSHA now discounts that bleach does not kill mold, and the EPA followed suit. I have attached a very good link to the EPA on mold http://www.epa.gov/mold/index.html and another link to the .PDF brochure on A Brief Guide to Mold, Moisture and Your Home http://www.epa.gov/mold/pdfs/moldguide.pdf
These links will provide some good knowledge, yet, for remodelers, who are not experienced in water, wind and fire losses (any property losses involving moisture content or water damage), you can contact me for further advice. Dealing with any type of water damage loss to a structure must involve the proper drying of the structure and possible remediation before repairs are made.
My posting falls under the category of insurance restoration, which is a specialized field. I have worked the restoration and adjuster sides of the insurance fence for the last 16 years throughout the country.
I hope this info helps. Don't hesitiate to ask any more questions.
Insuranceclaims is offline
The Following 6 Users Say Thank You to Insuranceclaims For This Useful Post:
ApgarNJ (05-12-2010), BuiltByMAC (05-12-2010), griz (05-12-2010), KennMacMoragh (05-13-2010), RCT (05-13-2010), wallmaxx (05-12-2010)
Old 05-12-2010, 07:09 PM   #13
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
I've never heard of this. I've always used bleach with good results. Have had some jobs with horrible mold problems, and approximately 10 years later, I still see no indication of the mold rearing it's ugly head again. I wonder what determines the success, or not, of bleach irradiating the mold? I suppose I should research a bit on the subject.
Thanks for bringing that up ApgarNJ!
Jeff G is offline
Old 05-12-2010, 07:20 PM   #14
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I've also heard that bleach doesn't kill the mold, it well....bleaches it making you think it is gone.
Angus
angus242 is offline
Old 05-12-2010, 07:58 PM   #15
You can use water and detergent on certain materials. But if it's wood, the EPA recommends using wood floor cleaner. http://www.epa.gov/mold/table2.html
Old 05-12-2010, 08:05 PM   #16
FStephenMasek's Avatar
Trade: helping people avoid problems with toxic materials
Rewards Points: 268
Insuranceclaims has good advice. Even dead mold spores can bother people, so you want to clean it away. You can wire brush or sand the wood (in containment, with one man holding the house from the HEPA VAC and the other using the angle grinder with a wire brush or sander). After you are done, Foster 40-20 or Fiberlock IAQ are good biocidal encapsulants.
________
Wong Amat Tower Condo Pattaya
FStephenMasek is offline
Old 05-12-2010, 08:13 PM   #17
Fire up the BBQ
griz's Avatar
Rewards Points: 1,180
Hey Insureanceclaims, I sure am glad you spoke up. Very accurate and extremely well put. Thank you.
griz is online now
Old 05-12-2010, 08:28 PM   #18
Handle It!
MALCO.New.York's Avatar
I do NOT have ANY faith in "Organic" cleaners. A mixture of Bleach and TSP ARE the U S Forest Services suggestion.
As for Mold of ANY type located in a substrate or behind walls........ Replacement of the wood is the ONLY fool-proof remedy! The dead Mold Spores left behind are a PERFECT host for NEW Mold to grow!
http://www.buildings.com/tabid/3413/...5/Default.aspx
Ultimate Wisdom---------
MALCO.New.York is offline
Old 05-12-2010, 08:47 PM   #19
Jaf's Avatar
Trade: Builder
Rewards Points: 250
TSP is Tri-sodium phosphate. Really heavy duty commercial cleaner. What I've heard is you spray a water bleach mixture on the mold to 'kill' it. Then scrub with a brush and the TSP mixture. The TSP is corrosive to your skin, so you need to wear gloves.
I've seen TSP that if you read carefully isn't TSP, but some "safe, TSP like, skin and frog friendly, substitute", You want real TSP, hot water, and rubber gloves.
My info is years old, and is probably only good for run of the mill mold. But, IMO any mold I see, is run of the mill. Unless "told otherwise", in which case I'd have the client call in the mold pros.
I know there was a big mold scare several years ago, but I've never met a customer, who had any serious mold concerns. If I ran into one, I'd probably back away until they brought in someone who knew more about it.
Jaf is offline
Old 05-12-2010, 08:51 PM   #20
MattMatt
mwhafner's Avatar
Trade: Remodeling/Renovation
Rewards Points: 75
Living in an area that has recently experienced major flooding, I have spoken with several specialists in this area over the last couple weeks. Insuranceclaims advice is 100% right from what I have gathered. Don't mess around, and get your homeowner to spring for an hygienist's opinion.
The most logical remediation I have heard is
- to first treat the infected area with soda blasting, or sprayed with ammonia or peroxide
- then prime the affected lumber with a good quality primer.
mwhafner is offline
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
What brought mold to this room and how to clean it? Eric S General Discussion 10 09-18-2009 10:52 PM
Mold remediation Kostyan General Discussion 17 09-17-2009 07:54 PM
Mold growth on framing? jhark123 Business 24 03-17-2009 02:24 AM
New Construction Showing Mold... thepawnshop Construction 13 10-20-2006 06:43 PM
