What Is The Best Way To Keep A Fence Post From Rotting
Old 03-07-2011, 07:54 PM   #1
Irishmann07's Avatar
Trade: carpenter
i have to install a cedar fence and was wondering what is the best way to keep the posts from rotting. red cedar thanks
Irishmann07 is offline
Old 03-07-2011, 07:56 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: What Is The Best Way To Keep A Fence Post From Rotting
Leave at least 6 inches and even better 12"'s of space between the ground and the post.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 03-07-2011, 08:02 PM   #3
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
DURO TUBE galvanized steel never rots! just kidd'n...
If you live in a state ware you can still get liquid copper soak the ground end of your post in that over night thats the best way to keep a wood post from rotting. If you cant get liquid copper all the other brands are about the same.
SAW.co is offline
Old 03-07-2011, 08:02 PM   #4
Trade: carpenter
i have to bury the posts in the ground 24 inches. i was wondering what to coat them in. In concrete, dust, gravel thanks
Old 03-07-2011, 08:32 PM   #5
MplsGC's Avatar
Rewards Points: 25
I guess it depends on how sturdy they need to be. They will rot less in gravel then concrete but only going 24" down this post sounds like it will not stand for long. I usually go 1/3 of the above ground hight into the ground, pour concrete to just above finish grade and taper concrete away from the post to allow water to run off. This is simple and works for about 15 years or so.
We have been using PT cedar post for the last few years. I have no idea how much longer they will last but maybe as mush as 20 years?
MplsGC is offline
Old 03-08-2011, 03:28 AM   #6
Rob PA's Avatar
In our area, code has changed over the last few years. Its kinda funny, your not allowed to submerge a post in cement. As the cement increases rot, they are really trying to get away from anything in the ground due to the run off of the PT additive. You can still submerge the post in, then back fill. It all depends on the code offices attitude that day. Anything structual, like decks or such, have to set your hole with the cement then bracket your post to it. I wouldnt do it on a fence, would end up with a million pot holes of cement. I would say gravel. Chances are by the time the posts start to go, then fence will already have issues.
Facebook
Rob PA is offline
Old 03-08-2011, 04:14 PM   #7
Trade: carpenter
thanks everyone
Attaching a post to foundation wall.. bujaly Decks & Fencing 21 09-29-2008 10:55 PM
Fence post depth ? daArch Decks & Fencing 11 12-03-2007 09:38 AM
