Weight/volume Of Stucco
Old 03-29-2007, 08:14 PM   #1
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
I've got a customer who wants the stucco removed from her house and then resided with wood. Anyone have a number per 100 sq. ft. for the weight and volume of stucco. Anyone done this? What kind of time does it take? Any other tips? Tks, Rich.
reveivl is offline
Old 05-11-2007, 09:04 PM   #2
Remodelers's Avatar
Re: Weight/volume Of Stucco
I've done a few stucco tearouts. I don't have the math down on the weight. The hardest thing is busting or cutting it into manageable size pieces. I have run across different densities, but the pain the butt part is the wire.
You could probably do the calcualtion based on concrete weight and factor a little less. On tearouts I worked on the stucco was from 3/4" to about 1 1/4" thick. 1"x12"x12" will give you the volume. Find the weight for a given volume and do the math.
I'm Really In A Place Where I'm Not Trying To Be Anything Other Than What I Am.
Remodelers is offline
Old 05-11-2007, 09:10 PM   #3
Remodelers's Avatar
If I did the math correctly, it should be 12.5 lbs per square foot for concrete. Stucco is probably a little less. 1100-1200lbs per 100 s.f is my guess.
Old 05-11-2007, 10:06 PM   #4
reveivl's Avatar
Trade: Renovations
Thanks for that, can you cut it into chunks while still on the wall, then get it to the dumpster? seems that would be easier than dealing with the wire/stucco in a heap on the ground. Problem I've had with cutting stucco to install windows or something is the diamond blade cuts the stucco great, but wears out real fast on the wire. Is there a better tool/device for cutting this crap?
reveivl is offline
Old 05-12-2007, 08:24 AM   #5
Thom
thom's Avatar
Rewards Points: 4,748
I've done several. Cutting the wire is the issue. Cut it on the wall with a diamond blade, pull it off the wall with your hammer claw. You will spend as much time cleaning up the debris (sand/mortar) left on the ground as you will doing the tear off.
thom is offline
Old 05-12-2007, 08:51 AM   #6
reveivl's Avatar
Trade: Renovations
Tks Thom, you've got me really looking forward to this. Oh, well, it's not like I'll actually do more of it than show the guys anyhow.
reveivl is offline
Old 05-12-2007, 12:55 PM   #7
Remodelers's Avatar
Keep a pair of wire cutters around or what I like is a pair of tin snips for cutting the wire. I have used both a hammer and a diamond blade for cutting out manageable sections. Anyway you look at it, it's messy.
Old 05-12-2007, 11:06 PM   #8
Tscarborough's Avatar
Rewards Points: 1,402
Don't fight the lathing, use it. Break off enough stucco at the top to get a good grip on the wire, and then peel it off in toto.
Tscarborough is offline
Old 05-15-2007, 04:57 AM   #9
daparsonshsc's Avatar
Trade: General Contractor, Remodeling
Rewards Points: 16
This is just a test
daparsonshsc is offline
Old 12-12-2016, 11:30 PM   #10
gwrichardson's Avatar
Trade: Roofing
Rewards Points: 14
Make sure you wear an appropriate mask. Breathing cement causes IRREVERSABLE DAMAGE to your lungs. You won't ever get it out, and you will die a premature death. I learned this the hard way.
gwrichardson is offline
Old 12-12-2016, 11:31 PM   #11
Trade: Roofing
Rewards Points: 14
Common sense says to open the box, not science.
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 10:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 08:10 AM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 07:09 AM
new skim coat over old stucco 415moto Construction 6 07-12-2006 07:28 PM
repairing stucco ceilings and cracks Zeebo Painting & Finish Work 10 12-21-2005 05:43 PM
