Water Leaks, Foundation At Ground Level
Old 03-06-2018, 07:54 PM   #1
la_bacon's Avatar
Rewards Points: 4
I live in the Phoenix area and have been increasingly coming across this problem. At some point, someone encloses a carport to turn it into a garage. However, there isn't the standard 6" between the ground and top of the foundation, so water will leak into their garage. Usually there is maybe 1/2" between the ground and top of foundation, sometimes it's actually below ground level and sometimes there are concrete walkways adjacent to them at the same level (that are not redirecting the water properly). They definitely don't want to spend the money to re-pour a foundation, and digging the ground lower usually isn't an option because it would be on their neighbor's property.
If posts or bottom plate really need replacing we will jack up the house and replace them. At that time we try to run a moisture barrier underneath the wood and wrap it up a few inches in the interior as well as the exterior. Then we silicone it at the foundation. We also hold the drywall up a few inches and use cement board siding as a baseboard. We also recommend gutters and French drains.
If replacing boards is not an option, we do the best we can to weatherproof with an adhesive flashing and top it with an elastomeric product or use silicone.
The nature of the structure requires our siding (typically cement boards) to come in contact with the ground (or adjacent sidewalk) which I know isn't recommended but anything else would expose the studs underneath.
Does anyone have any recommendations on how to improve this process?
la_bacon is offline
Old 03-06-2018, 07:59 PM   #2
Bull Trout's Avatar
Rewards Points: 990
Re: Water Leaks, Foundation At Ground Level
You can spend the money to do it correctly, or you can scab a temporary "solution" to the problem
If the customer cant afford 24' of proper foundation, they probably shouldn't be remodeling
Bull Trout is online now
Old 03-06-2018, 08:03 PM   #3
la_bacon's Avatar
Rewards Points: 4
Well there's a lot of people that would rather scab than tear down a 350 sq ft structure. Just want to do the best I can for those guys.
la_bacon is offline
Old 03-06-2018, 08:07 PM   #4
Bull Trout's Avatar
Rewards Points: 990
it doesn't need to be torn down to be done correctly
Old 03-06-2018, 08:13 PM   #5
la_bacon's Avatar
Rewards Points: 4
Yeah, unfortunately it's still way out of their budget. Even this is pushing their budget. If we don't scab it for them, they are just going to get someone else that will. And from the scabs I've seen tried on these homes, they aren't going to be doing a better job and will potentially be making things worse.
la_bacon is offline
Old 03-08-2018, 01:53 PM   #6
MTRmatt's Avatar
Rewards Points: 4
See that situation around my parts fairly regular. HO's enclose carports or back patio slabs and wonder why waters coming in around the plates.
Theres no solution that they will like hearing.
I just priced one out for a young couple just beforw the holidays. They calles me out to replace some sill,stud , and sheathing rot. What i found was that not only was the back addition slab below grade, no footings and a false wall sitting on dirt to hide an old retaining wall (actually , now the bearing wall) from when it was a patio slab. My price was to temp support roof, demo walls as needed, cut the slab back and pour new footings, block or concrete up to 8" above grade and reframe walls. Trying to keep as much as we can as to keep cost down. Told him i cant do any type of half assed repair and leave with no footings
Poor couple just bought this place a month earlier. Its in limbo now as lawyers are involved.
MTRmatt is offline
Old 03-11-2018, 01:21 PM   #7
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,890
You could install Concrete blocks fill the insides with concrete and wire and reinstall sillplate But you will still have to address drainage around the perimeter.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is offline
Foundation leaking at water main. DLynch0009 Masonry 10 12-19-2016 10:37 PM
Ground Level Deck joylynn Decks & Fencing 5 06-16-2016 05:49 PM
Cracked foundation, water damage, mold? kamilran Construction 11 01-13-2015 10:17 PM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 08:51 PM
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
