Water Damage
Old 01-15-2006, 08:24 PM   #1
Dusty's Avatar
Trade: Carpenter, Contractor
Question
Water Damage
Howdy Folks, I'm happy to be a registered user at last. This is a great place!
A customer has had water leaking in some chimney flashing. That's been fixed as of a few days ago. On the inside there is blistering paint and some plaster damage, No problem. Here's the question:
How long would you wait for it (the walls and ceiling space) to dry before repairing the plaster and paint?
I know there are plenty of factors and I intend to drill holes, contain the areas, and add heaters to the rooms.
Any Ideas, experience or feed back would be greatly appreciated.
Dusty is offline
Old 01-15-2006, 08:42 PM   #2
Peladu's Avatar
Re: Water Damage
Moisture meter? Maybe? A week.
My first concern would be mold.
Heaters in an occupied house?
Peladu is offline
Old 01-16-2006, 10:33 AM   #3
Dusty's Avatar
Re: Water Damage
Moisture meter should help, thanks. Yes it's an occupied house, with very large rooms. The Idea is to set up temporary walls and increase the temperature in the areas of the room that are to be addressed.
Dusty is offline
Old 01-16-2006, 03:46 PM   #4
Chippy ?
chippy185's Avatar
Trade: wannabe paint pro
Re: Water Damage
well,you can also use a air blower+ a dehumidifer,there is also a product called milgo,which takes care of any mold issue
chippy185 is offline
Old 01-29-2006, 10:10 PM   #5
Construction and Remodel
juniorchilli's Avatar
Trade: general contractor
Re: Water Damage
You can rent fans designed for this purpose, also dehumidifiers. If you use heat you will increase the chance for mold growth. Use cool air and a mildicide to control the mold \mildew. you can get this from a water damage supply house or restoration company in your area. Good luck.
JuniorChilli
juniorchilli is offline
Water Damage Repair AtlanticWBConst Drywall Picture Post 7 06-15-2010 11:00 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Carpet Water Damage tribe_fan Flooring 6 08-08-2006 09:18 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
