Wall Pulling Away
Old 05-01-2013, 09:13 PM   #1
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Wall Pulling Away
We've been working in this house for almost 4 months now. We knew this wall had been damaged by a tree, but I just noticed that it's gotten worse since we gutted the rooms several weeks ago.
I was on the phone off and on with our architect and engineer most of the day comming up with ideas, neither have been out to see it in person. All they've seen are the pictures Ive posted here.
So any ideas are welcome.
jlsconstruction is offline
Old 05-01-2013, 09:15 PM   #2
stacker of sticks
Rewards Points: 590
Re: Wall Pulling Away
wall pulling away-forumrunner_20130501_211443.jpg   wall pulling away-forumrunner_20130501_211509.jpg
Old 05-01-2013, 09:15 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Can you provide a link to the pics?
Never mind I see them now....
griz is offline
Old 05-01-2013, 09:16 PM   #4
stacker of sticks
Rewards Points: 590
Just posted them
Old 05-01-2013, 09:18 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 8,614
Jesus. What is holding it to begin with? Push it back with a machine and hit up the old Simpson catalog.
Morning Wood is online now
Old 05-01-2013, 09:18 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,275
Ratchet straps to pull the wall plate back together, then sister the plates and studs and tie into existing perpendicular walls.
Easy Gibson
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
ICBuilds (06-25-2013), Sir Mixalot (05-01-2013)
Old 05-01-2013, 09:20 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Warren & MW are both correct....
But WHY did it move like that?
griz is offline
Old 05-01-2013, 09:24 PM   #8
stacker of sticks
Rewards Points: 590
I did try today, with only a 1/4 of movement. I'll try some more in the morning.
I was also entertaining the idea of getting an excavator over here and pushing it in, but that seems scary.
Old 05-01-2013, 09:27 PM   #9
stacker of sticks
Rewards Points: 590
That's what I'm more concerned about, and how to prevent it from happening again.
The house is 110 years old, balloon framed.
Old 05-01-2013, 09:29 PM   #10
Box Builder
Just add more wood
Old 05-01-2013, 09:29 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 18
It will take some serious sawzall work before that wall will move significantly...
I would still want an explanation as to what failed for the wall to move like that. That is the condition that needs fixing...
griz is offline
Old 05-01-2013, 09:31 PM   #12
Geometrist
Warren's Avatar
I would guess that the tree damage split the plate and studs right in line with where the ceiling joists were toe nailed in. Without the ceiling joist to prevent it from drifting out, that is exactly where it wants to go. The weight of the roof and friction of the nails is resisting your attempts to pull it back in. Might have to completely remove that top plate, clear any nail or wood fragments, reinsert a new top plate, and pull the wall in. Simpson does make some hangers that would go around the joists and onto the wall to make the connection secure.
Easy Gibson
The Following 4 Users Say Thank You to Warren For This Useful Post:
griz (05-01-2013), hdavis (05-02-2013), Sir Mixalot (05-01-2013), tenon0774 (05-05-2013)
Old 05-01-2013, 09:35 PM   #13
stacker of sticks
Rewards Points: 590
Thanks guys. I'm looking at Simpson's website now
Old 05-01-2013, 09:53 PM   #14
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,700
I'm thinking that if you can lift the roof weight off of the wall ,you might be able to use a come-along to pull the wall back in, and use the appropriate ties to make it stay.
Second the new top plate.
B.D.R. is online now
Old 05-01-2013, 11:29 PM   #15
hdavis's Avatar
Rewards Points: 4,559
Simple, but expensive - exterior steel plates with threaded rods going through from outside wall to outside wall. Install, put on the bolts, and tighten.
You can also just pull it together with a bunch of comealongs.
hdavis is online now
Old 05-01-2013, 11:43 PM   #16
stacker of sticks
Rewards Points: 590
My engineer was talking about cable with comalongs with steel plates on the exterior.
First thing in the morning I'm going to start cutting out the top plate.
It's all true 2x4s so I'm going to see if I can track down some rough cut to.
Old 05-02-2013, 12:14 AM   #17
CarpenterSFO's Avatar
Rewards Points: 2,044
I did just this, after someone drove off an elevated parking lot and crashed a car into a 2-story apartment building, with similar damage. Get the thing stabilized first, so it doesn't just flop apart. And don't run any big machines into it, unless you want to be on the 5-oclock news. Find all the obvious sticking parts and clean up with sawzall. Pull it together with plates and threaded rod - which is way more forceful than a come-along, and much less susceptible to scary lurches. Crank on some tension. The sticking points are easy to find - they're the places with a solid thunk when you hit them with a sledge. Deal with the sticking points one by one, with sawzall or a sledge. Crank on more tension. Rinse and repeat. That looks like sunlight through the planks, so you can smack it?
A screw jack might help if a joist has dropped.
I was standing outside the building I worked on after fixing it, bragging to anyone who would listen, and relating all the gossip about the drunkard who had done it, when the guy I was talking to got a funny pained look on his face and said that he had done it and that he wasn't drunk, he'd simply hit the gas instead of the brake.
Anyway, I say slow and easy - no running big machines into it.
- Bob
CarpenterSFO is offline
The Following 3 Users Say Thank You to CarpenterSFO For This Useful Post:
TimelessQuality (05-02-2013), Tom M (05-02-2013)
Old 05-02-2013, 12:20 AM   #18
stacker of sticks
Rewards Points: 590
Thanks sfo
How many thread rods did you use.
Old 05-02-2013, 01:24 AM   #19
Thanks sfo
Maybe 5 or 6. We had a pile of long all-thread - 8 & 10 footers, holddowns and washers and nuts in inventory, so we just grabbed them all. We had to drag the bottom plate in in a few spots, too. We also had some header material - 4x10 I suppose - that we used to pull sections in.
I'm really slow and careful about this sort of thing. I saw a building come down on my dad when I was a teenager. He lived, but it was a close thing for a while.
- Bob
Old 05-02-2013, 08:02 AM   #20
hdavis's Avatar
Should have gotten back to this sooner. I see SFO has covered practically everything. I wouldn't cut out the top plate until I have stabilized it all, figured out exactly how I was going to pull it together, and done as much prep as possible.
If you use cables / comealongs, put tension and then sledge from the outside - if you try to do the full pull with the cable, cable stretch makes it slide further than you may expect when it starts moving. Tension then sledge - if it doesn't move, put some more tension on it, sledge again. Being slow and careful can go a long way to saving the structure and your butt.
Using threaded rod, you can leave everything in place once you're done - the structure will be stronger than ever. It's my preferred approach.
CarpenterSFO (05-02-2013)
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 01:14 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 01:00 PM
Masonry Wall Art Picbrick junie General Discussion 4 07-26-2012 04:51 PM
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 08:20 AM
