Vapor Barrier/ Roofing Underlayment
Old 02-22-2008, 07:24 PM   #1
fast pasquale's Avatar
Trade: Hardwood flooring contractor
I've gutted a bathroom in one of my rentals. It was built in 1929. Its down to the studs now.. Anyways.. my first question is.. Im obviously going to insulate the outside wall. Do I need a vapor barrier too?? Which would be .. Studs, then insulation.. then vapor barrier.. right?.. Something like 6mil plastic? The house was/is not insulated. Someone told me to put up roofing underlayment, then insulation, the 6mil, then cement board.. Do I need the roofing uderlayment?.. If so do i cover all three walls of each stud bay??What do you guys think??
Thanks
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 02-22-2008, 07:32 PM   #2
Re: Vapor Barrier/ Roofing Underlayment
Can't imagine why one would use the felt.
Stuff R-13 unfaced batts and staple
at least 4 mil (6 mil is good too) visqueen
over the stud faces.
neolitic is offline
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
Roofing Felt for Garage Floor Tile Underlayment res0zvle@gmail. Flooring 4 10-26-2007 09:21 AM
Production Manager - Roofing (Seeattle WA) raynproof Help Wanted or Looking For Work 0 10-12-2007 05:31 PM
Minnesota Roofing tekwrytr Roofing 0 09-11-2007 03:06 PM
