Trailer park boy
Truck Or Mixer?
Say you need just over 1 yard of concrete to fill a bunch of hellish sonotubes tucked under the structure with about 12" clearance above them (all shovel work to get the crete in the tubes) , would you get a truck in and have it sit while you wheel and shovel or just buy premix bags and get out the trusty old mixer? (there is no place to stock sand and gravel to mix your own)
"Industry without art is brutality"
New and Remodel Carpentry
Trade: General Contractor/Remodelor
Re: Truck Or Mixer?
On something like that you are better of with the bags. 1. You can control the time needed to pour and finish each sonotube. 2. your late charges on having that truck sit will be high(not worth it to me).
Trade: Builder/ Remodeler
Re: Truck Or Mixer?
I would pull out the mixer and get the bags going. Saves money and you can control the mix. With only the 12" of clearance it gives you better flexability to make sure all the mix gets into the tubes.
Chief outhouse engineer
Trade: mason
Re: Truck Or Mixer?
Just poured a footer two weeks ago, called for .8 yds. Since I was laying block on top of the footer I had sand and pea gravel delivered along with Portland and everything else I needed (except for the mortar
) We mixed and poured it in about an hour. I used pea gravel cause any thing bigger is pretty tough on a paddle mixer. If I had a drum mixer, I could have used bigger stone. I don't think it was a problem in this particular situation. Its still a lot of scooping. BTW it takes about 40 bags (#80) to make a yard.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
Gumby
Trade: Concrete
Re: Truck Or Mixer?
Yes in this case I would probably mix bags.
However this situation comes up a lot so here is my logic. 1 cubic yard =42 80lb bags of sackrete. Each bag does 2/3 of one cubic foot. Depends on how much you waste; drop, fail to get out of mixer etc A bag costs $4.00 in general after tax. To rent a small mixer costs about $50.00 for me. Cost to mix 42 bags is $168+50= $218. My ready mix company will send 1 yard at $100.00 and a short load fee under 5 yds = 125 + environmental and fuel surcharge= $225.00 99% of the time I will get the Ready mix. In the last 3 years I have had 2-3 jobs where I just had to mix by hand. The last possibility in my area is make your own mix. A truck of rock runs over $300.00 A load of Sand is over 300.00. Just not a possibility here. In Texas it was $6/ton back in the day. Sand was cheap too and you could get small loads delivered or you could pick them up. Similar up North in Washington State. Site access is always the deciding factor for me. Getting bags to site takes hours, delivery is 15-60 bucks depending on locale. It takes x minutes to load and mix bags. If I were you, you might get some retarder added by Ready Mix Company or add it on site. Wheel barrow to a chunk of plywood by each tube; Make a large box and haul it around then get rid of truck and fill your sono tubes. How many men you have with you? You should have about 1hr or more with the retarder depending on temp, humidity wind etc. Sonotube finishing??? Bang and strike off or round top for water drain. I have even heard some Ready mix has built in pump. Here pump is seperate and runs $350.00 minimum. Honestly I might have tried to build that in the price. Enough thinking out loud! Last edited by IanS; 09-26-2009 at 05:35 PM. Reason: More musings |
Trade: GC/Transportation
Re: Truck Or Mixer?
Site mix truck, save the headache and your back.
And some of them have built in pumps. |
Trailer park boy
Re: Truck Or Mixer?
The crappy thing is sackrete comes in 55 lb bags around here (that is what is stocked anyway)
68 bags @ 5 bucks a bag = $340 (yea 5 bux a 55 lb bag) Truck cost me $300 even with wait time and short load charge, and I got it done in 1.5 hrs versus all day mixing.
Trade: contractor
Re: Truck Or Mixer?
grout pump!
Trade: General
Re: Truck Or Mixer?
does any rental place have a pull behind concrete trailer? I ave used them on occasion, about 155/yrd
Designer/Contractor
Re: Truck Or Mixer?
Ready mix, pump, and factor in the price.....................
solar guy
Trade: solar contracting
Re: Truck Or Mixer?
what about a batch mix truck
for anything less than a yard I always went bags. Me and a helper can mix and pour a bag in less than 2 minutes with no spillage and no equipment other than a piece of poly. Works particularly well on a deck with hanging posts. or perhaps in this situation. |
| Mixer Truck Question | Rick Rowlands | Masonry | 16 | 08-10-2009 09:17 PM |
| 10 Wheeler TRUCK W/ CAT C-12 99 STERLING W/8 40 YARD DUMPSTERS! | Paradise | Vehicles | 0 | 07-24-2009 02:38 PM |
| need advice on dead truck & removing/selling Kargo Master ladder rack | jordanski | Vehicles | 12 | 06-03-2009 08:29 AM |
| Morter Mixer Vs Cement Mixer | personalt | Masonry | 6 | 07-29-2007 09:16 PM |
| Painted My Truck With a Roller | ModernStyle | Painting & Finish Work | 44 | 07-21-2007 10:11 PM |
