Tiling Bathrooms Walls
Old 09-26-2006, 12:58 PM   #1
tate16t's Avatar
Trade: Roofing
Is there a general rule for the height of the tile? I'm planning to tile the entire bathroom halfway up the wall. The shower/tub is one unit so this area will not be tiled.
tate16t is offline
Old 09-26-2006, 05:56 PM   #2
Tom R's Avatar
Re: Tiling Bathrooms Walls
I don't know of any specific rule or standard for it, - - but I usually end up anywhere between about 54" to 64", - - wherever it's most convienient and pleasing to the eye, - - and based on a 'full-tile' pattern plus border, - - so that the border crosses over your light switch (which is usually at about a 48" point or lower). In other words, - - border above light switch but below eye level.
http://www.tr-built.com
Tom R is online now
Old 09-26-2006, 09:31 PM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Wow, 54 to 64? We somewhere usually install 36" to 39" for tile wainscotting.
Mike Finley is offline
Old 09-26-2006, 09:35 PM   #4
mdshunk's Avatar
Because I often have to RotoZip new boxes in tile walls in bathrooms, I think I can offer an opinion on this matter. The 'above 54 inches' is more traditional and old-school. The 'below 45 inches' is more modern and contemporary. I observe an equal mix of both. What they're accomplishing with that measurement disparity is "completely below the switch box" or "completely above the switch box". The switch box normally spans the space from 47 to 52 inches.
mdshunk is offline
Old 09-26-2006, 09:57 PM   #5
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Whatever the person writing the check wants.
Looks like some pros were here.
Gordo is offline
Old 09-26-2006, 09:58 PM   #6
mdshunk's Avatar
Just not through the middle of a switch or outlet box, or your electrician will flatten your tires.
mdshunk is offline
Old 09-26-2006, 10:01 PM   #7
Gordo's Avatar
You must have fun roto-zipping through some of the porcellinato tile we put up.
I haven't found a roto-bit that will cut that stuff outside of using tile 'spade' bits and a small cold chisel.
Gordo is offline
Old 09-26-2006, 10:06 PM   #8
mdshunk's Avatar
Yeah, I had to put a recessed light in a tile shower that was an "afterthought". It was really hard fired porcelain tile. I bought two 10 packs of tile bits, and used all but a few. This was a small 4" can. If it was something a little larger diameter, I might have been able to finesse a 4" diamond grinder around. That was my education on how hard some tile can be.
They need to make RotoZip diamond bits.
mdshunk is offline
Old 09-26-2006, 10:09 PM   #9
carl owens's Avatar
Trade: remodeler
I Say Above The Switch.
The Payee Has The Final Say.
Ill Do The Cieling Long As I Get The Check.
Carl
carl owens is offline
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
concrete walls finishing mjay Masonry 2 03-05-2009 03:36 PM
If using SW, Which Specific Product for Walls, Ceiling and Bathrooms? bradesp Painting & Finish Work 13 01-09-2006 09:04 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
