Thinset Or Plywood, Or Tar Paper First?
Old 06-17-2017, 09:54 AM   #21
Mordekyle's Avatar
Rewards Points: 3,234
Re: Thinset Or Plywood, Or Tar Paper First?
I thought you woke up at 5 AM?
Mordekyle is offline
Old 06-17-2017, 11:08 AM   #22
VinylHanger's Avatar
Rewards Points: 7,422
I do, but not by choice. Mornings suck.
VinylHanger is online now
Old 06-17-2017, 12:10 PM   #23
Unger.const's Avatar
Rewards Points: 2,662
He is even crankier when rocks fall in him......
Unger.const is online now
Old 06-17-2017, 12:56 PM   #24
Old 06-17-2017, 07:20 PM   #25
Put2use's Avatar
Trade: Remoldeling
Boo hoo need a Kleenex?
Put2use is offline
Old 07-22-2017, 06:42 PM   #26
KermieB's Avatar
Trade: Remodeler, Kitchen and Bath
Rewards Points: 315
Originally Posted by Put2use View Post
Partical Board? Is a mobile home. Wow. Good luck
Wrong grasshopper. Particle board was the preferred underlayment in virtually every home in the south built between 1970 and the mid '90's. I see it in every job I do. You just rip it all out and start over. Two drops of water and it swells up like a sponge.
KermieB is offline
Old 07-22-2017, 06:44 PM   #27
KermieB's Avatar
Rewards Points: 315
Originally Posted by GreenSpringbok View Post
Good day to you all...
I have some conflicting reviews on this topic, and thought I would bring it here.
On a bathroom remodel, we have pulled the tub, vanity and existing tile. The existing floor is two layers of subfloor, but both are particle board.
My current plan is to remove the top layer and replace it all with hardy board... and then here starts my questions.
1) I have only heard one person say that they glue the hardy board to the lower sub-floor later, this sounds crazy, I would use many screws to make sure there is no squeeking.
2) The most important question I have, for the shower stall, I am planning a curbless entry with a forward slope to the shower doors. I am using the QuickdrainUSA product which so far seems like a good way to go. I am using their 58" linear drain and their quickslope product and the kit they supply for waterproofing.
Their instructions report to put thin-set directly to the plywood, then lay backerboard (I assume hardy) , then right onto the hardy a layer of thinset and then their quickslope material.
I have in the past been under the impression that you should always place tar-paper with mesh on top of the plywood, and then any cement / thin-set or mortar or anything like that otherwise the wood just draws all the moisture from the thin-set.
Does anyone here have any view on these questions?
Thanks
WOW... there is so much about this thread that tells me that your clients' lawyer will be contacting you in about three years wanting his money back and his bathroom rebuilt.
KermieB is offline
Old 09-26-2017, 01:25 AM   #28
Flip King
Gking707's Avatar
Trade: Remodel Contractor
Rewards Points: 38
I can agree about that
Gking707 is offline
Old 11-02-2017, 11:23 AM   #29
Jrno1's Avatar
Rewards Points: 80
Thanks
I glue the cement board down Hardie board or ideally Bond it with thinset and screw it. And then my favorite top-of-the-line product Red Guard! Anywhere there could be a moisture issue.
Jrno1 is offline
Shingle brand that comes in brown paper package? alwayson Roofing 14 05-09-2018 09:03 PM
1/4 pine plywood , self-leveling compound, Ditra somuchtolearn Tiling 2 06-15-2014 08:42 PM
Custom paper overanalyze Wallpaper 4 01-30-2013 07:51 PM
Paper Faced Metal Bead... or??? Rich D. Drywall 27 01-12-2013 12:22 PM
Block laying, felt paper questions Bradracer18 Landscaping 6 03-23-2011 09:36 PM
