Technical Question: Basement Wall Insulation & Vapor Retardants (under 2006 IRC)
Old 12-20-2008, 06:20 PM   #1
Panzer5's Avatar
I'm working in Kentucky (Zone 4) which requires R10/13 insulation for basement walls under the 2006 International Residential Code (which KY adopted in late 2007). The question is whether I need to install the insulation as a remodeler - when I am not modifying the existing concrete - or whether I can rely on the existing walls...?
I'm working a bid to remodel a homeowner's unfinished basement in a home that's probably 5-7 years old. The basement is a dry, conditioned space, with unpainted concrete walls. I noticed that the joists for the floor above do not have insulation showing between the first floor and the basement space. If the basement walls were insulated at all, it would have to be on the dirt side of the concrete.
Because I plan to frame (2x4 & drywall) adjacent to the concrete walls - I need to know whether I have to install R13 batts & a vapor barrier (increasing my costs) - or whether I can simply frame & drywall.
Unfortunately, the code isn't exactly clear on this; and I'm having a hard time finding the answer on the net.
Anyone know the answer to this?
(This question could come up again given that fully half the houses in my area were built from the late 1930's through the early '60s. I presume those older houses have no insulation in the basement walls - but again, the IRC doesn't address whether the remodeler has to install insulation to meet code...)
Panzer5 is offline
Old 12-20-2008, 06:25 PM   #2
genecarp's Avatar
Re: Technical Question: Basement Wall Insulation & Vapor Retardants (under 2006 IRC)
Can not speak for your exact location, but if you are finishing, and heating a basement, i would be wrong to not insulate, no customer in there right mind would want to shortcut that step. As far as the code, if you have filed for permits, and there will be inspections, you will be required to insulate based on your post. G
genecarp is offline
Old 12-20-2008, 06:38 PM   #3
Panzer5's Avatar
That's my problem. The HO asked me not to insulate or install the vapor barrier - as a way of reducing my costs. I told him what the code requires - but we're in a debate as to whether that is actually required given the relatively new construction of his basement.
I suspect I am in competition with another builder who's willing to not install any insulation or vapor barrier - which mean's he's able to significantly undercut my price.
Panzer5 is offline
Old 12-20-2008, 06:40 PM   #4
theman's Avatar
5 You are changing the use of the basement from storage to living space.
the basement MUST meet the 2006 IRC code. check the insulation on the
out side of the foundation. you might be ok or just add a few inches on the inside, thats why no insulation was added to the ceiling. speaking of ceiling how what is the ceiling hgt. also youwill need to have a second means of egressout of the basement. and please get a bld. permit
al
theman is offline
Old 12-20-2008, 06:55 PM   #5
Sean
SLSTech's Avatar
Panzer - sorry but Gene & Al are correct
Codes are codes & even then they are minimum standards
Trust me when the HO has issues later, they or some representative of theirs (Insurance Company, etc...) will be coming after you for not building to code & your insurance will not cover it
SLSTech is offline
Old 12-20-2008, 06:55 PM   #6
Panzer5's Avatar
Wouldn't proceed without the permit. But I'm one of those anal types who likes to have everything laid out in my contract up front & my plan made before I get the permit.
Ceiling height is good (> 7ft), so I don't need a height variance.
- the egress requirement might be a deal killer for the HO... He's quibbling on a lot of things & asking me to rebid (i.e. how much to leave the walls drywalled & doors hung, but no paint, no trim, no tiling on BR floor, no carpet elsewhere, drop ceiling instead of drywall, etc. etc.) (makes me really consider charging for bids in the future!)
Frankly I'm thinking about walking away from the opportunity -- even though I could use the money. Bottom line though: while I'm willing to work with homeowners, as SLSTech writes: codes are codes. I just couldn't find the exact answer to this question in the book.
Panzer5 is offline
Old 12-20-2008, 07:38 PM   #7
Ivinni's Avatar
Trade: High Rise Caulk and Insulation
There is "basically" no R value to concrete (technically).
http://www.concreteconstruction.net/...8&refresh=true
The R-value of an uninsulated, 8-inch-thick basement wall built using normal-weight concrete is 1.35, based on data from the 1993 American Society of Heating, Refrigeration, and Air-Conditioning Engineers' Handbook. By doubling the thickness of the wall to 16 inches, the R-value only increases by 0.50.
Does the HO know what omitting the insulation will do to his heating bill? Let the HO know that the cost of the insulation, amortized over a 5 year period, will pay for itself and return money on his investment after that for probably the life of his addition. (generally)
That should help to make the sale.
its not going to get better with straps, or new footings or even aroma therapy.
Ivinni is offline
Old 12-23-2008, 12:41 PM   #8
Tom M's Avatar
Dont know your area and what R-value or AHJ requirement's you have but ridgid insulation will eliminate a pissing match with the building dept. I have seen in a local building dept a presciptive wall design that put's the vapor barrier on the inside (warm side for us)and a 1/2" min air gap on the back of the wall. I think the air space is a safe idea but think that prescriptive method is the wrong approach to basements. On another note we also have a provision in the UCC that exempts basements from insulation with a mechanical trade off. The trade off is a based on buildings with High Efficency equipment through out. I guess the logic is a more efficent unit omits less warm air loss in the mechanical room or house.
In NJ we also deleted the word"basements" in the IRC so only sleeping rooms need the egress escape.
Tom M is offline
Old 12-23-2008, 03:08 PM   #9
Code Nerd
Deadhead Derek's Avatar
Trade: Historic Preservationist / Furniture Maker
per code, IRC, AJ501.2 states that you may not make non conformities worse ( paraphrased) but as you are changing occupancy from basement to living space, no code related loophole at all, and the non conformities are moot. insulate away...
www.darkstarltd.net
Hand-crafted Traditional Masonic Furniture
and Coffins
Deadhead Derek is offline
Old 12-23-2008, 04:07 PM   #10
Check your code on the egress,
ours is amended to require the
egress windows only in sleeping rooms.
neolitic is offline
Old 12-23-2008, 05:20 PM   #11
Kgmz's Avatar
How can you not know the codes, laws, rules for your own state.
After a quick search here is your info from the,
The Kentucky
Building Code
Ninth Edition
2007
Second Printing
As Adopted
3401.3 Compliance with other codes.
Alterations,
repairs, additions and changes of occupancy to
existing structures shall comply with the provisions for
alterations, repairs additions and changes of
occupancy in the
International Fire Code, International
Fuel Gas Code, International Mechanical Code,
Kentucky Plumbing Code, International Residential
Code and NFPA 70.
3403.1 Existing buildings or structures.
Additions
or alterations to any building or structure shall comply
with the requirements of the code for new construction.
Additions or alterations shall not be made to an
existing building or structure that will cause the existing
building or structure to be in violation of any provisions
of this code. An existing building plus additions shall
comply with the height and area provisions of Chapter
5. Portions of the structure not altered and not
affected by the alteration are not required to comply
with the code requirements for a new structure. If a
fire wall separates the existing portion from the
addition, both buildings shall comply with the height
and area provisions of Chapter 5 as separate
buildings.
Also here is a PDF of the Kentucky Energy Code Workbook.
http://dhbc.ky.gov/NR/rdonlyres/ACD9...rkbook2007.pdf
Kgmz is offline
Old 12-23-2008, 05:49 PM   #12
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
If this looks like something you will be doing a lot of or even just this one, pop into your local building dept and speak to one of the inspectors there to be clear. Sometimes it saves conflict in how one inspector to another as to what code defines. But seeing they will be the one to say yes or no, now would be a good time to speak with them, prior to any pricing and especially work performed.
I dunno if in your area every few years or so the tax accessor request a walk thru just to be sure of proper evaluation of homes, (more taxes they can charge) if they see a completed basement when before there was not one, your name may arise as to the one who made the change, a check with permitting office fails to show a permit was pulled, the what?
This possibility alone is worth always pulling the needed permits, not to mention if ever a fire, water damage resulting in an ins claim.
This is when H/Os sureley forget you reminded them about codes and proper procedure.
Besides always good to pop in your local building dept just to wish all there a very Merry Christmas
Wishing you & yours a very Merry Christmas.
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Scaffolding Question, distance from wall plazaman Masonry 20 09-24-2008 08:31 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Plaster on Basement Wall, Dirt! mattleaders Construction 0 10-16-2006 11:22 PM
Knee wall Insulation ? baspinall HVAC 0 10-07-2006 10:39 AM
Open Basement Wall; Insert Window? Help, Please! bluethumbnail Framing 5 08-25-2006 12:45 PM
