Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling
Old 02-04-2009, 01:22 PM   #1
P.R. Rescue Guy
AboveAndBeyond's Avatar
Sump Pump - Burying the Line Deeper - How Deep?
I have a customer whose sump pump drainage line keeps freezing up (a bit deserved - he only buried it a couple of inches,) and of course, it's not tossing water out of his basement since the line is frozen.
My projected course of action is to bury to exit line deeper into the ground for its entire course into the yard, I'm thinking 3 ft deep but this is honestly arbitrary—how deep would you guys recommend this line be to keep from freezing?
Is there anything else I should consider in this situation that I might have overlooked.
His sump pump is relatively new and works fine in warmer weather.
AboveAndBeyond is offline   Reply With Quote
Old 02-04-2009, 01:56 PM   #2
New User
AutumnWood Inc.'s Avatar
Trade: Deck Builder
It's all in the pitch, how deep should not matter, as much as the pitch will. You should have an overflow tee just outside of the basement wall so it will at least drain there. It has to run to daylight also or city sewer..
AutumnWood Inc. is offline   Reply With Quote
Old 02-05-2009, 01:42 PM   #3
jmic's Avatar
City sewer is a big No No. But you are right if it's pitched properly with no bellies in the pipe it would not freeze.
Joe
jmic is offline   Reply With Quote
Old 02-05-2009, 04:09 PM   #4
New User
Trade: Deck Builder
Sorry, I was refering to curb sewer not waste sewer, That use to be ok in our area to tie into. Or where do you route the sump line in city areas?
Old 02-11-2009, 12:22 PM   #5
P.R. Rescue Guy
thanks everyone for the advice, we temporarily resolved the problem by running a heated & pitched drainage line from the exit point of the pump, however the H.O. wants it buried and pitched once the ground unfreezes. talk about job security.
cheers.
Paint or stain on hardi plank? Jer Painting & Finish Work 25 12-24-2009 01:10 PM
Sump systems that mount above grade? wackman Plumbing 8 01-16-2008 08:38 PM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
Stinky Sump Pump spin69 Plumbing 1 12-10-2005 10:44 PM
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 20 04-25-2004 10:38 AM
