Stucco Tearoff - Best Practice?
Old 10-04-2009, 01:37 PM   #1
JeffeVerde's Avatar
Trade: G.C.
I have to peel 80 l.f. of stucco off an 8' wall. I've done plenty of window/door cutouts, but this is the first time I've taken down a whole (BIG) wall of stucco. What's the best way to attack this -- cut it top to bottom every couple stud bays and take it down in manageable chunks? or just start ripping and break it up once it's down?
JeffeVerde is offline
Old 10-18-2009, 11:53 PM   #2
Designer/Contractor
Rio's Avatar
Re: Stucco Tearoff - Best Practice?
If you have a high volume air compressor you can chip it vertically every two to three bays and then pull it right down or if you don't mind the dust and the wear on the motor bearings you can do a similar thing with a carborundum blade on a rotary saw (like a Skilsaw) and then once again peel it off in big chunks. If you work behind it with crowbars or big pry bars sometimes you can really pull down big chunks but if they get too big they're hard to handle.
Rio is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Stucco patch NAV Masonry 9 05-26-2009 03:41 PM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Please help with stucco texture Josh Hildebrand Masonry 1 03-17-2009 11:05 PM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 07:25 AM
