Stepped Foundation Walls In 1924 Home
Old 11-18-2016, 01:40 AM   #1
herynkc's Avatar
Hello,
I am doing some research on the possibility of adding a second story onto my 1924 home. I am trying to gain some insight on what the 2 to 3 foot wide 48" tall stepped sections adjacent to my basement wall are for. They go around the perimeter of 3 of the 4 basement walls. Were these added to the home some time after its initial construction while turning a crawlspace into a full height basement? Or do they have some other purpose?, i.e to function as a type of footer for the foundation walls? Here is a photo of my basement.Thanks in advance for any input on this.
Stepped Foundation Walls in 1924 Home-img_2969.jpg   Stepped Foundation Walls in 1924 Home-img_2972.jpg
herynkc is offline
Old 11-18-2016, 05:29 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,020
Re: Stepped Foundation Walls In 1924 Home
We can only make assumptions, I never seen anyone doing that, but who knows who did that and what were they thinking.
Maybe they didn't expected so much dirt to come out, so they left some dirt around perimeter,formed around it and filled it with concrete or whatever they used there or maybe they were afraid existing crawlspace foundation caving in after dirt was removed, so they did that to provide additional support... WTF knows what they were thinking.
greg24k is offline
Old 11-18-2016, 07:14 AM   #3
Hiber's Avatar
Rewards Points: 60
I've seen that don't to older foundations in an attempt to sure up a degrading stone foundation. Usually only go as high as the grade outside. Also to stop water penetration through the failed mortar.
Hiber is offline
The Following User Says Thank You to Hiber For This Useful Post:
hdavis (11-18-2016)
Old 11-18-2016, 07:52 AM   #4
tgeb's Avatar
Rewards Points: 254
Regardless of why someone did that, you will need to dig some test pits to verify what the existing footer conditions are. Then consult with a PE and get his take on whether your existing foundation is capable of handling the increased load of a second story.
Anything else is just speculation.
www.gebcon.com
tgeb is online now
Old 11-18-2016, 08:13 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 298
Lots of time it was done on older houses with no real basement just a hole for the furnace. Then people decided to do a basement ,dug them out and did a wall like that to hold back the dirt and foundation of the old walls. Very common around here to see.
Randy Bush is offline
Old 11-18-2016, 09:11 AM   #6
MikeFL's Avatar
Trade: Engineer
Rewards Points: 196
We would need more information before we could advise you. There are several possibilities.
1) The inside wall carried the original building and a porch or addition was added later.
2) Someone made a crawl space into a basement.
3) It was originally built as a basement with porch around the perimeter and at some time someone replaced porch columns with a stemwall.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline
Old 11-18-2016, 09:37 AM   #7
herynkc's Avatar
Ok, I will get out there and dig a few pits to see what the circumstance is with those 3 walls. As I said before, however, this stepping is only done on 3 of the 4 foundation walls. So 1 of them I can see goes to the floor of the basement (84" H). This I find strange...
There was an addition to the home maybe 40 years ago, but its footprint extends beyond the footprint of the basement walls. It sits on 4x4s supported by concrete blocks (something I will change)
Thanks
herynkc is offline
Old 11-18-2016, 10:06 AM   #8
hdavis's Avatar
Rewards Points: 3,481
All of the ones I've seen that on had unstable stone foundations that were encased in concrete.
hdavis is online now
Old 11-18-2016, 12:36 PM   #9
herynkc's Avatar
Well from the digging I've done so far, the soil here is pretty rocky. So this seems to correspond with your experience. Then those steps are probably solid concrete all the way back to the exterior foundation walls?
herynkc is offline
Old 11-18-2016, 12:58 PM   #10
madmax718's Avatar
Trade: General
Rewards Points: 3,202
. While not definitive (you need an architect/structural engineer), those are quite common place where you are digging adjacent to an existing foundation wall for the purpose of things like making a cellar/basement where there was only a crawl space, or to increase ceiling height.
You have some other items that are somewhat strange going on as well.
Whats going on with that beam support? It looks as if the concrete was formed around the post a little bit. Looks like some reinforcing work was done previously, it is possible that the house had shifted previously, maybe due to inadequate foundation. It is also possible they decided to fix the problem, and while "they were in there" decided to dig out a little more.
What is the black piping in pic 1? And what is that pipe opening in pic 2?
madmax718 is offline
Old 11-18-2016, 06:58 PM   #11
herynkc's Avatar
So In the first photo you are just seeing the old carburetor from my truck hanging down off the ledge, things are a bit messy as ive just moved in 2 months ago...
The posts are not cemented in. What you are seeing is actually blue-gray paint that ended up on the post when they painted the foundation walls.
The pipe in the second photo is a remnant of what I believe was an incinerator or coal furnace of some sort. It was built into the stepped section of the wall. Here are some additional photos. One of them pictures the inside of this "furnace". The walls, at least in this section, do extend all the way down to the floor of the basement. The space is comprised of cinder blocks.
As far as I can tell, the current basement heights was always this high. The cement composition and texture seems consistent throughout. I dont think the stepped walls were from a crawlspace being converted into a full heights space, but I could be mistaken.
I will consult a structural engineer.
Stepped Foundation Walls in 1924 Home-image1.jpg   Stepped Foundation Walls in 1924 Home-image2.jpg   Stepped Foundation Walls in 1924 Home-image3.jpg
herynkc is offline
Old 11-18-2016, 07:08 PM   #12
herynkc's Avatar
The more I look at things, The most I think all the walls are cinderblock cover with cement.
herynkc is offline
Old 11-18-2016, 09:14 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 642
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is online now
waterproofing inside of basement walls -new poured foundation TIGHTER MITER General Discussion 13 04-30-2013 09:57 PM
Blasting stone basement foundation walls blastoffinc Sandblasting 11 08-05-2012 08:27 AM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 03:35 PM
Fixing crumbling foundation walls? D. Jones Const Masonry 1 04-28-2011 01:49 PM
Illinois Mechanics Lien Forms and Instructions Ed the Roofer Business 4 02-23-2008 08:58 PM
