Sound Proofing A Bathroom
Old 05-25-2007, 11:36 PM   #1
RussellF's Avatar
Send a message via Yahoo to RussellF
I am presently in a small bathroom(5'x8') remodel and the customer asked me if I could do something to make the bathroom more sound proof. The only thing that I could come up with was to just put insulation(R-13) in the walls. I was also thinking of putting some pipe insulation on the copper piping. I would be interested in what you all have to add to that. Some specs. : 2x4 studded walls, solid pine 6-panel entry door(new).......I have never seen a bathroom studded out 2' o.c. Thanks for any and all replies.
RussellF is offline
Old 05-26-2007, 12:56 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Sound Proofing A Bathroom
fur out the wall or walls over the existing drywal then add another layer of drywall that doesnt touch the existing drywall.
Mike Finley is offline
Old 05-26-2007, 02:10 AM   #3
Woz the Painter's Avatar
Build 6 foot thick walls with rebar enforcement, should do the trick.
Oh PS no windows!
Woz the Painter is offline
Old 05-26-2007, 09:10 AM   #4
Thom
thom's Avatar
It's almost impossible to add sound deadening at this point. Insulation in the walls will help but much of the sound travels through the framing.
You could put in a cheap exhaust fan. These fans are loud enough to mask bathroom noises. Another benefit is they are loud enough that they don't get forgotten about and left on, blowing conditioned air away.
thom is online now
Old 05-30-2007, 07:21 PM   #5
Big Bob's Avatar
Trade: GBC & Roofing ReM Comm & Res & Insured loss restoration
You are on the right trac, no need to go overboard. add a bit of caulk down the wall cavity ( backside of wall to stud) FG insul ( stuff R-19 if you can) or use duct board, Density of FG is key to a sound blanket) will deaden the dreaded toilet flush. 1000 series JM might be best but not worth your $ special order.
Big Bob is offline
Old 05-30-2007, 07:45 PM   #6
The Grand Wazoo
KillerToiletSpider's Avatar
They make accoustical insulation, very dense stuff for recording studios, but they recomend you put cork in under the drywal when you use it.
KillerToiletSpider is offline
Old 10-22-2007, 12:25 AM   #7
Terrence's Avatar
Trade: painting and carpentry
You should suggest they don't eat chili or pot roast... or start using bean-o.
Terrence is offline
Old 10-22-2007, 12:36 AM   #8
Fentoozler
Celtic's Avatar
LMAO
....when the alternative just isn't acceptable
Celtic is offline
Old 10-30-2007, 10:33 PM   #9
troubleseeker's Avatar
Look into a product called "quietrock". It is acoustical sheetrock and available up to some incredible specs. Your local drywall distributor should be familiar with it, don't expect much more than a blank stare from the typical lumber yard.
troubleseeker is offline
Old 11-01-2007, 05:33 PM   #10
gitnerdun's Avatar
Trade: plumber
Some carpet on the floor and some kind of soft wallpaper should absorb the sound waves rather than let them bounce around like hard surfaces do.
gitnerdun is offline
Old 11-01-2007, 08:10 PM   #11
FrankT's Avatar
On my own bathroom I did the following and had good results.
1. Installed foam pipe insulation on the water pipes.
2. Wrapped the waste with some heavy tape I had that is similar to Ice and Water Guard. This worked good.
3. Calked all openings for pipes, wires, etc (ALL) including the top and bottom plates. (This probably helps the most)
4. Fiberglass insulation in wall.
I did some research on an Audio/Video website and learned that sealing ALL openings helps a LOT. You can also laminate the sheetrock. More mass helps to dampen sound. There is a product call "Green Glue" that is used between sheetrock laminations to help dampen sound transmission.
Frank
FrankT is offline
Old 11-01-2007, 08:59 PM   #12
Carpenter/fencing
nywoodwizard's Avatar
Didn't know taking a dump could be so noisy
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 11-02-2007, 06:10 PM   #13
plazaman's Avatar
what about that spray foam insulation ?
plazaman is offline
Old 11-05-2007, 08:33 PM   #14
Tom M's Avatar
I would look into the quiet rock. Also an air gap of any knid is often the best deadening. When you have 2 skinney walls spread apart verses one layered wall the sound weakens or vibrations. You can use a sill seal for sills and plates also will help. I think it works under the same principals as for heat tranfer when clearance for combustibles matter.
Tom M is offline
Old 11-05-2007, 08:46 PM   #15
Home Serve's Avatar
Trade: siding windows soffit fascia
How bout making it easy: Install a 500 CFM fart fan in center of ceiling. That should do it with little fan fare and little $$.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 11-10-2007, 09:55 PM   #16
May as well make it brown and yellow shag whike you're at it (if you're not old enough to have been around in the 60's that will mean nothing).
Did you miss his mention of the word "bathroom"?
Old 11-18-2007, 11:16 AM   #17
GenConJ's Avatar
soundboard under the drywall is a good option if you can lose another 1/2" all around.
Air-borne noise escapes and penetrates rooms at the door more than anywhere else
GenConJ is offline
Old 12-17-2007, 09:37 PM   #18
dunn2500's Avatar
Trade: general contractor
i was just thinkin same
dunn2500 is offline
Old 11-20-2011, 02:18 PM   #19
Linear Shower Drains
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Who here has tried using the sound control membranes from either Mapei or Noble Company?
We are spec'ing a job in False Creek that has a By Law against jetted tubs in the Condo. We will be using Noble Companies Sound Control Membrane to block out the noise generated by the Jacuzzi Tub so the owners below my clients are not disturbed at all.
This is a first for me and I'm looking for info on prior installs. A testimonial or two will go a long way in the Strata meeting when I present the sound control measure we will take here in Vancouver. A necessary hurdle to get a green light to start this bathroom renovation project.
My thoughts are that if the tub is placed over Sound Control Membrane and Tile we will block a ton of noise. Then by using Safe and Sound insulation inside the unit we will further block the noise transfer between condos.
Please share some prior job feedback if you can.
This is the product I plan to install.
Nobleseal SIS
Some more info here.
Found this product online http://www.soundproofingamerica.com/...ndproofing.asp
This is going to be a cool project and will feature a Ledgestone Water Fall that has a Fiber Optic Light feature. Too bad we don't start demo until Spring or Summer.
John Whipple (By Any Design Ltd.) - Member of Terrazzo Tile and Marble Association of Canada, the National Kitchen & Bath Association and the National Tile Contractors Association. Specializing in Vancouver bathroom renovations, linear shower drain installations and shower waterproofing procedures.
JohnFRWhipple is online now
Old 11-22-2011, 11:23 PM   #20
clancrawford55's Avatar
Trade: Renovation, Custom Homes
Quietrock is by far the best option. You might as well roll a cig with the $ you would spend on the R-13. We have used it in home theaters & it is easly twice as effective as double 5/8" & sealant sandwich, + you only need to hang one layer of 1/2"
L. J. Crawford
Whit's fur ye'll no go by ye!
Failing means yer playin!
12 Highlanders & a Bagpipe make a Rebellion
clancrawford55 is offline
Bathroom Paint Problem - Strange Peeling firemike Painting & Finish Work 23 09-27-2007 07:53 PM
sound proofing JamesNLA Construction 2 12-20-2006 05:17 PM
Inexpensive sound proofing methods Humble Abode Construction 30 10-27-2006 07:18 AM
sound proofing izote61 Construction 6 12-09-2005 09:16 AM
Sound Proofing HVAC Equipment hoek HVAC 1 10-05-2005 10:42 AM
