Smoke Damage
I am working on a fire damaged kitchen. Tear out and replace no problem. My question is: Can I clean the smoke damage from the rest of the house or do I need to go to bare studs?
Are there produxcts out there that can rid the house of smoke smell? Thanks |
Re: Smoke Damage
Soda blasting and BIN
Thom
Re: Smoke Damage
Clean then seal. Kilz works. You've got to seal everything. If the attic was smoked, you've got to paint all the rafters and decking and joists. EVERYTHING. There's a reason fire damage is costly to repair.
Trade: Residential and Commercial Remodeling
Re: Smoke Damage
I heard that orange stuff works best (can't remember the exact name- think it was citrus based??). Then again it didn't work so hot in our house, when I accidentally tossed a pillow ontop of a burning candle then left the room- came back and the bed, mattress, and wall were on fire!!
Just that little bit of fire, and it smelled sooo bad! Good luck with that!
Trade: general contractor
Re: Smoke Damage
It really depends on the extent of the damage! I did smoke and water restoration for a couple years and unless it was fairly minor we stripped down to studs,sprayed with kilz then re-insulated and rocked.You definately don't want to take a chance of left behind smoke odor contaminating your new work.If it is minor you can seal it with kilz or similiar product and repaint.They make what is called a chemical sponge it looks like a big eraser,that can be rubbed on very lightly smoked walls and ceilings to remove soot and odor.Also make what is called a therma-fogger kind of like one of those insect foggers that you put a special chemical in and fog the house to help remove odor.Really if you aren't comfortable with doing it I would recommend subbing that part out to a disaster restoration company!It would really bite to do all the work and still have an odor the HO held you responsible for!
Re: Smoke Damage
Thanks for the replies. Excuse my igorence, but what is BIN? I am assuming soda is baking soda, not Pepsi
Thanks again Will keep you posted! |
Re: Smoke Damage |
| Fixing termite damage | ODDBALLS | Framing | 3 | 08-03-2007 09:32 PM |
| smoke detector info for residential applications | az electrician | Electrical | 6 | 04-06-2007 07:14 PM |
| Source for Smoke bombs??? | a1plumbingyakim | Plumbing | 3 | 01-11-2007 12:51 AM |
| Smoke Damage? | CoastalCoatings | Painting & Finish Work | 13 | 02-16-2006 10:22 PM |
| smoke damage | kenvest | Painting & Finish Work | 6 | 11-07-2005 09:31 AM |
