Shower Part II
Old 09-29-2006, 07:08 PM   #1
jerome8283's Avatar
Trade: Roofer
Shower Part II
Hey Guys,
I took the shower out today. I posted pics below.
I have a couple of questions.
1. During demolition a peice of the drain broke. It was the piece that existed just above the shower hole. Is this going to be a problem?
2. Can I extend the shower pipe and outlet upwards a bit? It has always been too low. What is the standard height?
Shower Part II-img_9293.jpg   Shower Part II-img_9294.jpg   Shower Part II-img_9298.jpg
jerome8283 is offline
Old 09-29-2006, 08:08 PM   #2
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Re: Shower Part II
Go ahead and frame your curb. Then call your plumber to install a pan.
Do not try this your self. Plumber will tie the drain and pan in, then you will be ready to tile.
Are you a HO?
Looks like some pros were here.
Gordo is offline
Old 09-29-2006, 08:09 PM   #3
jmic's Avatar
Re: Shower Part II
While you have it all torn apart I would change out that diverter and adjust your shower spoyt accordingly.
Joe
jmic is offline
Old 09-29-2006, 08:49 PM   #4
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
Are you a HO?
Yes. I do Masonry work. This is my first attempt at a shower pan install.
I picked up this book, http://www.amazon.com/Complete-Guide.../dp/1589230620 which provides step by step instructions for the pan install. It appears pretty straight forward.
How much would a plumber charge to install a shower pan?
Old 09-29-2006, 08:59 PM   #5
Celtic's #1 Fan
mahlere's Avatar
Trade: electrical
Re: Shower Part II
not nearly as much as they will charge to remove the shower and fix it after you screw it up. It only looks straight forward until the real install stops looking like the picture in the book. Good luck. I am positive that you can do it, but plan on several attempts and a lot longer time frame than you planned on.
mahlere is offline
Old 09-29-2006, 09:21 PM   #6
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
Ghee thanks
Old 09-29-2006, 09:34 PM   #7
tgeb's Avatar
Re: Shower Part II
Originally Posted by jerome8283 View Post
Ghee thanks
Jerome, throw the book out and run up to the ceramic tile and stone section of this forum.
http://www.contractortalk.com/f73/
Post asking for help w/a shower pan, RD or Bud Cline should be able to help you out. These guys are top notch and can walk you though.
A shower pan is not difficult at all. With your skills as a mason it should be a piece of cake. Plumbers rarely do it correctly any way.
From what I see of the photo you posted you need to remove some of the remaining old drain from the existing pipe. Looks like a gasket and metal cup from the old shower receptor is still attached.
I built my own shower pan and I am a just an excavating contractor.
PS. Nice demo job!!
And here is a link that will help.
http://ontariotile.com/preslope.html
www.gebcon.com
tgeb is offline
Old 09-29-2006, 10:06 PM   #8
Peladu's Avatar
Re: Shower Part II
I agree 100%...
Peladu is offline
Old 09-29-2006, 10:34 PM   #9
Gordo's Avatar
Re: Shower Part II
You already know I think you should hire a plumber........but if you want to go for it ....have at it.
Another side note as far as the carpentry goes.......add another 2x4 stud on that back wall where the drywall looks to be 'floating'. This will also give you something to screw your tile backerboard to. Skim coat using 20 mud this transition and the one next to entry door.
Also, is the floor 3/4"? Beef up the shower floor with another layer of 3/4" to prevent 'deflection' that may crack your mud floor.
Plumber in my neck of the woods would charge $500 for pan, and diverter (Delta 1700) change mat. and labor. Well worth it.
Gordo is offline
Old 09-29-2006, 11:00 PM   #10
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
Thanks. The top layer is 3/4" but there is another layer beneath, it's hard to tell what it is. The floor does appear stronger in this area.
Old 09-30-2006, 01:23 AM   #11
Remodeler
lxdollarsxl's Avatar
Trade: Remodeler/Painter
Send a message via Yahoo to lxdollarsxl
Re: Shower Part II
can you get to the drainage from beneath the stall?
Damned if im gonna do it more than once.
lxdollarsxl is offline
Old 09-30-2006, 07:30 AM   #12
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
No.
Old 09-30-2006, 08:05 AM   #13
Gordo's Avatar
Re: Shower Part II
What is underneath? Even if it is ceiling, you may have to cut a hole to access underneath. Or you could cut a square around the drain on the top side and piece it back in.
Call a plumber.
Gordo is offline
Old 09-30-2006, 08:23 AM   #14
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
Call a plumber.
Why do I need to get underneath Gordon?
Old 09-30-2006, 10:23 AM   #15
jerome8283's Avatar
Trade: Roofer
Re: Shower Part II
I was able to get the drain off. It just required a little more muscle and careful maneuvering.
Also, I confrimed again, the floor consists of two layers of 1/2" or 5/8" plywood.
Old 09-30-2006, 01:18 PM   #16
747's Avatar
Re: Shower Part II
i also agree i would install new antiscalding valve when its open. I have no ideal about shower pan the drainage pipe looks like trouble. I say
MIKE FINLEY
747 is offline
Old 09-30-2006, 03:12 PM   #17
Gordo's Avatar
Re: Shower Part II
To tie in the drain.
Gordo is offline
Old 10-01-2006, 12:54 PM   #18
Moderator
Double-A's Avatar
Re: Shower Part II
A push-on shower drain can be installed from the top side, as can a solvent weld PVC bodied drain.
Or am I missing something?
New York Times, July 20, 2006
Double-A is offline
Old 10-01-2006, 08:43 PM   #19
tgeb's Avatar
Re: Shower Part II
Yes, the extra work involved to cut a hole in the ceiling, and the repairs related to that.
www.gebcon.com
tgeb is offline
Old 10-01-2006, 08:48 PM   #20
Gordo's Avatar
Re: Shower Part II
See what I mean? A plumber will solve your problem.
Gordo is offline
shower pan C.C.R. Plumbing 4 08-02-2007 11:01 PM
shower base C.C.R. Ceramic & Stone Tile 11 07-30-2007 10:56 AM
Fiberglass tub / shower refinishing RightConnection Kitchens & Baths 3 04-23-2007 10:04 PM
glass block entry to shower Mr. D Masonry 10 12-04-2006 02:14 PM
Question about shower system... Knyte260 Plumbing 59 10-24-2005 06:05 PM
