Res. Contractor/Cabinetry
Trade: Residential contractor
Shower Pan Holding Water
Remodeled a shower about 9 months ago. Plumber set new PVC pan.
Tile company did everything else including pitch. Water seams to be sitting on the far side under the tile. The pan seams to be doing its job of keeping the water in the "pool" that it creates. I think the pitch is not right and the water is seeping thru the grout and collecting. Is this possible? Can this be fixed without tearing out this whole shower?? If floor tile is removed can the pitch be fixed and then retiled? Customer has said they put multiple coats of grout sealer on the grout. Could this cause a problem? |
Trade: custom home building
Re: Shower Pan Holding Water
How can you tell that water is collecting under the tile?
#3 | |
Builder/Remodeler
Re: Shower Pan Holding WaterQuote:
As Cleveman said, how are you observing the water "under the tile"?
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Did anyone install any pre-slope below the membrane that the plumber installed?
With out a pre-slope water will lay in the mortar bed, even I know that. And I'm an excavator. |
copycat
Sounds like a do over. Pre slope under the membrane is critical. Water seeps through the thinset and mortar so the membrane must be sloped as well.
strikes and gutters, ups and downs |
Sponge
This is why we have the phrase "do it right the first time" Sealer is not problem.
If water is under tile and there is tile movement then it will only get worse
San Diego Kitchen Remodeling Room Additions in San Diego Bathroom Remodeling in San Diego San Diego Electrician Kitchen and bath remodeling & Room Additions. |
| Supplying hot water to 4 apartments | joesauers | Plumbing Picture Post | 8 | 03-30-2009 08:18 AM |
| Shower leaks / Tile / new construction | keytermite | Ceramic & Stone Tile | 9 | 03-27-2009 08:05 AM |
| Hot Water Heater making loud sound and vibrating the entire wall | BKFranks | Plumbing | 9 | 10-27-2008 10:58 PM |
| Water Heater and well water question | silvertree | Carpentry Picture Post | 0 | 03-14-2008 09:16 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
