Sheetrock Removal From Foam??
Old 11-08-2017, 01:19 PM   #1
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 424
Anyone got any suggestions?? I have been working on this little bit for a while now, 🤔 pick and chisel and shovel it up,
Sheetrock removal from foam??-imageuploadedbycontractortalk1510168519.690037.jpg
I do have my Drywaller coming to look and see if he texture over this, looks like it had been plastered over, and it's kinda amateurish looking, but I believe it was designed that way
Sheetrock removal from foam??-imageuploadedbycontractortalk1510168723.048731.jpgSheetrock removal from foam??-imageuploadedbycontractortalk1510168742.500198.jpg
Jonbuild is online now
Old 11-08-2017, 05:13 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 90
Re: Sheetrock Removal From Foam??
treat it like wallpaper & wet down
as for poor texture job, sand & refinish
SLSTech is offline
Old 11-09-2017, 02:10 PM   #3
Jonbuild's Avatar
Rewards Points: 424
Seriously!!! That would take a lot of water...
I did have the Drywaller stop by, and he pointed cracks that I had not noticed, the plaster got hair line cracks that we fear would show through once painted, there's tiny bubbles that I had not noticed, and we did notice it looks like we maybe getting some condensation through the ceiling...
So the Sheetrock coming off weather I like it or not, the ceiling and exterior walls are easy, it's where they foamed from the back side that's hard.... don't ever underestimate the strength of foam,
Old 11-09-2017, 03:53 PM   #4
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,172
If you could make a few vertical channels and remove the screws some how, maybe a guitar string or wire behind with dowels on the ends for handles and sort of wire saw it off.
That's a dilly of a pickle though.
Philament is offline
Old 11-10-2017, 06:38 PM   #5
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Why not use a demo hammer, damage some foam, then fix the foam?
I'm approaching it from a "time is money" view though. I know foam ain't cheap, but damn it sure looks like your doing it the slowest way possible.
Another idea: the bent sawzall blade trick.
www.callbathdoctor.com
Driftweed is offline
Old 11-10-2017, 06:54 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,445
I would run an electric carving knife behind it, 6" at a time, remove as you go down the wall.
Or find a serrated sword.
MarkJames is offline
Old 11-10-2017, 07:23 PM   #7
JAH's Avatar
Trade: carpenter
Rewards Points: 1,812
I'm not a big fan of adding a 2nd layer of sheetrock. However in your situation it seems like a reasonable option. If the wall is half stripped pads the studs and overlay the rest.
JAH is online now
Old 11-10-2017, 08:57 PM   #8
Jonbuild's Avatar
Rewards Points: 424
Demo hammer does work, but I didn't have the right chisel, wished I had a floor scraper, or a curved tile chisel, nobody in town had one, we don't have a lot of options as far as just go to the next lumberyard,
That said, my preferred weapon was a small pick, or a small straight blade adze, then in the tight spots clean up with demo hammer
Yes there will be foam repair, if it was easier to take all the foam out with the drywall, I would have done that, using the sawzall was a tedious joke!!
I just got a little section to finish yet, 👍🏻 it's not so bad once you just put your head down and do it.
I'll take some pics when I finish it on Monday,
Old 11-10-2017, 09:17 PM   #9
wazez's Avatar
Trade: masonry
Rewards Points: 766
Did you try dynamite?
Sent from my SM-G860P using Tapatalk
wazez is online now
The Following User Says Thank You to wazez For This Useful Post:
Jonbuild (11-11-2017)
Old 11-10-2017, 11:04 PM   #10
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 896
Just sheet over it. Did you do asbestos testing?
I only ask cause that texture looks 70s
cedarboarder is offline
Old 11-11-2017, 08:33 AM   #11
Jonbuild's Avatar
Rewards Points: 424
That oughta do the trick just fine and dandy!! 😃
Old 11-11-2017, 08:46 AM   #12
Jonbuild's Avatar
Rewards Points: 424
This was built in early 2000's, it was plastered with color mixed in it to look like 70's, unfortunately it was a chitty job, with the changes we are making some areas need to be accessed.... hence the removal,
Old 11-11-2017, 02:03 PM   #13
Trade: Workaholic
Rewards Points: 896
I would use an oscillating saw and biggest blade you can get. 3" inchs at a time.... talk about tedious.
or... go to town and call spray foam company...
Old 11-20-2017, 12:06 PM   #14
Jonbuild's Avatar
Rewards Points: 424
Alright!! I finally finished this thing up!!! About a week ago...
Sheetrock removal from foam??-imageuploadedbycontractortalk1511200570.239066.jpgSheetrock removal from foam??-imageuploadedbycontractortalk1511200591.272729.jpg
I have to ask my foam guy, but this kinda looks like it may have been sprayed a bit to thick??
Sheetrock removal from foam??-imageuploadedbycontractortalk1511200756.022845.jpg
It had a lot of that, most places had 4 or 5" I think may have been sprayed in one pass
Tools that were tried Sheetrock removal from foam??-imageuploadedbycontractortalk1511201100.875449.jpg
Pick and long handled chisel were favorite
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 02:57 PM
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 12:39 PM
Spray foam insulation and Vapor barriers in bathrooms Zenscapes.ca Remodeling 9 10-22-2012 07:01 AM
coating removal bassinhunter Pool Construction & Enclosures 0 03-10-2012 11:28 AM
foam spray gun vs canned foam AustinDB Tools & Equipment 4 12-03-2008 07:30 AM
