Running An Exhaust Duct In Existing Condo Inbetween Floors - Help? - Remodeling - Contractor Talk
Old 12-01-2017, 11:16 PM   #1
GoodLJohnny's Avatar
Trade: General Contractor / Handyman
Rewards Points: 78
Arrow
Hello,
I'm a contractor in So Cal.
I have a client that wants me to run a duct through the ceiling inbetween the second and third floor. It's an exhaust for a dryer.
There's an exhaust for a bathroom that runs parallel to the line I would need to run, so I'm hoping the joists are consistent over that 10'.
My question is: what are the chances that I would run into blocking/other obstructions as I'm trying to run the ducting inbetween the joists?
I have done some work like this, but not a ton.
In the pictures you can see where the dryer is, where the bathroom and other exhaust fan is, where the bathroom exhaust vent is, and where the dryer exhaust vent would go.
I did peek in the can lights but did not pull one to see the joists etc. I could do this if I return.
Any suggestions are much appreciated!
L
PS I decided to post in remodel instead of HVAC, as it has more to do with the joists/blocks etc. If I should move to HVAC, please let me know. I just joined.
Running an exhaust duct in existing condo inbetween floors - help?-img-6594.jpg   Running an exhaust duct in existing condo inbetween floors - help?-img-6595.jpg   Running an exhaust duct in existing condo inbetween floors - help?-img-6596.jpg   Running an exhaust duct in existing condo inbetween floors - help?-img-6597.jpg
GoodLJohnny is offline
Old 12-02-2017, 08:43 AM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 2,226
Re: Running An Exhaust Duct In Existing Condo Inbetween Floors - Help?
No way to know.
Why isn't there one already?
Been there, done that. First stop is Condo association. Be prepared for mucho bool sheet.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Defenestrate (12-02-2017)
Old 12-02-2017, 08:54 AM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 4,150
He might be a small town guy but thats good big time advise take it
sunkist is offline
Old 12-02-2017, 10:29 AM   #4
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 18
Hope you and the client like drywall work...
If there's an HOA, start with them. HOAs have no shortage of nosy neighbors that'll put a monkey wrench in your plans... better to understand what you're up against beforehand. Plus, if you're lucky, you might get building plans.
Then offer a t&m contract to do exploratory holes in the ceiling. (Promise nothing except holes in the ceiling!) Try to establish if there's a beam perpendicular to the joists or anything else that's going to give you trouble.
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
SmallTownGuy (12-02-2017)
Old 12-04-2017, 11:48 AM   #5
Rewards Points: 78
Hi Everyone,
Thanks so much for the advice! Very helpful.
I will give him some thoughts, plus a proposal for investigative work.
Luckily, his unit is the one above the floor, so we don't have to deal with upstairs neighbors.
Yours,
L
Old 12-04-2017, 11:50 AM   #6
Rewards Points: 78
Also - I have a question:
For investigative work, my thought is to drill a small hole where the vent would be, and then run a fish line through and see how far it goes without obstruction.
Then, I could fill the hole with sikaflex etc. once we're done.
Is that better than starting with cutting holes in drywall?
Yours,
L
Old 12-04-2017, 04:50 PM   #7
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,146
You need to get a set of the new Makita X-ray vision glasses. Most of my clients don't understand why I dont have a set either.
Last week did a dog door to exterior set everything up got it perfect height in the stud bay perfect.
Cut out most of the sheetrock and right there 3 gas lines.
I guess what I am trying to say is you could get your liner all the way to the exterior wall then run into something.
Anderson is online now
The Following User Says Thank You to Anderson For This Useful Post:
SmallTownGuy (01-01-2018)
Old 12-04-2017, 10:44 PM   #8
Rewards Points: 78
Gotcha. I have the glasses on back order.
Thanks for the input.
L
Old 12-05-2017, 09:52 PM   #9
Box Builder
Morning Wood's Avatar
Rewards Points: 9,244
You really should get your head up in there to get a good look. Or a good scope camera or something. You are going to need to cut a couple decent size holes to run the duct anyway. You're using solid duct I hope
Morning Wood is online now
Old 12-05-2017, 09:53 PM   #10
Rewards Points: 78
Gotcha. Yes. I will write the proposal appropriately. Thank you.
L
Old 12-30-2017, 08:34 AM   #11
Pangdev's Avatar
Trade: general contractor
Rewards Points: 190
Make sure you have the homeowner contact the homeowners assoc.
If possible, have him CC you via email for all answers and responses. Good to keep as a log also in case anyone starts pointing fingers.
"DO NOT" do anything unless
1) you or the owner contacts the assoc
2) make sure you are fully insured.
I read about a contractor hired by a homeowner within a condo assoc. He was working in her bathroom with a torch. Set the entire building on fire. ( over 100 units )
Had no permit and not authorized by assoc.
Just my 2 cents
Pangdev is offline
Old 12-31-2017, 08:16 PM   #12
Rewards Points: 78
Just my 2 cents
Thanks Pangdev. I appreciate it!
Collapsible Duct for Air Mover Ethos Tools & Equipment 7 03-31-2013 09:10 PM
Condo - White Box Legal Definition and Builders Grade tpro123 General Discussion 2 12-20-2010 05:52 PM
Tie new foundation walls to existing? How? UpNorth Masonry 6 01-13-2010 10:32 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
Best way to Install 6" duct swp4lfe HVAC 1 08-14-2009 09:55 PM
