Rotten Beams - Must Replace
Old 02-26-2007, 06:26 PM   #1
MHMConstruction's Avatar
I posted this in the framing section too...
Rotten Beams - must replace
I'm doing a remodel and the house (old cracker shack, here in North Florida) had termites and the main affected area is a back corner of the house. It's set up on concrete block footings, about every 8 feet, and on top of the footings are 6x8 beams that run the length of the house, from front to back. The joists (2x8 old wood) sit on top of the 6x8 beams, and so forth.
The termite-eaten parts are about 3 feet long on both joining beams in the back corner. My plan is to get a few car jacks and set them up at 3 different locations in the back corner (possibly with a temporary 'joist to evenly support the lift), jack it up 1/4", and cut out the old rotten beams to the center of the next footing, and replace with.......
1) home made beam made up of 4 2x8's sandwiched together?
2) an 8x8 post, laid down?
what do you think?? And any other methods would be appreciated..
B.McCarthy
MHM Construction
Gainesville, FL
MHMConstruction is offline
Old 02-26-2007, 08:21 PM   #2
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Re: Rotten Beams - Must Replace
Steel if you can. LVL would be easier to to get into a tight spot. Take them in there one by one then nail them together down there and put them in place. Whats the span? And how many levels including roof will it be holding?
osborn is offline
Old 02-27-2007, 12:18 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Consult and engineer!
Cole is offline
Old 02-27-2007, 04:20 PM   #4
ContractorTalk Flunkie
dayspring's Avatar
I wouldn't lay a 8x8 down, it'd sag in time. Osborn had good advice.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 02-27-2007, 05:25 PM   #5
osborn,
when you say 'nail them down there' do you mean, to make my own LVL, like by nailing members together, or get a 7.5" LVL from the lumber yard?
i'm not really worried much about sag w/ the 8x8 - that's what's been holding it all up so far, but the existing beams run the length of the house - my repair it only spans about 8 feet (both ways, it's in the corner) and supports just one story. it's the back corner of the house, and the back corner of the kitchen.
not looking forward to it - looks like its my project for tomorrow. wish me luck
any more tips would be very helpful
MHM in Florida
Old 02-27-2007, 07:12 PM   #6
osborn's Avatar
Drag 2 or 3 members down there, sandwich them together, nail them 3 nails 16 o.c. and put in place. You could nail them together in the driveway if its not too awkward to get them down in the space. 1 inch tall for every 1 foot span.
osborn is offline
Old 02-28-2007, 10:15 AM   #7
recruit4meisner's Avatar
Trade: Electrical
Originally Posted by Cole View Post
Consult an engineer!
No question about it.
recruit4meisner is offline
Old 02-28-2007, 11:23 PM   #8
kapena's Avatar
Trade: General Building Contractor
Not for a 8 foot span. Osborn has the right idea.
kapena is offline
Old 03-05-2007, 04:45 PM   #9
osborn-
very good advice on putting it together one piece at a time - that saved my back.
I got 'er done today finally. I had to rent two 10-ton jacks and jack up the joists while removing the rotten beams. It wasn't fun, but looks good now.
many thanks,
MHM
Rotten window sill replacement jmancan Windows, Siding and Doors 21 10-15-2007 10:47 PM
FS 6"x10"x14' rough saw'n pine beams gsp Contractor Swap 2 06-05-2007 01:10 PM
Rotten Beams - must replace MHMConstruction Framing 5 03-17-2007 02:14 PM
Beams in Basement DrivenByDemons Construction 1 07-30-2006 03:16 PM
Help with painting rough cedar beams jgladdy Painting & Finish Work 9 04-21-2006 04:18 PM
