Roof Or Soffit Vent?
Old 07-31-2006, 05:35 PM   #1
ch0mpie's Avatar
Trade: Geotechnical PE
I'm renovating a kitchen, and I will be installing a vented hood over the stove. No shortage of space to run duct work, but there is not a wall to come out off. I'm trying to decide if it would be better to come out the roof or out of the soffit. If I go out of the roof(4/12pitch) I will only have a 12' run. If I go out of the soffit I will have to run about 20' and the soffit is about 5" wide.
ch0mpie is offline
Old 07-31-2006, 05:46 PM   #2
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Roof Or Soffit Vent?
Roof............ You don't want that greasy, moist air going out the soffit.
Get a roof vent designed for range hoods. They have a baffle in them that opens when the range hood is running, and closed when not in use.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 07-31-2006, 05:48 PM   #3
ch0mpie's Avatar
will do thank you
ch0mpie is offline
Old 10-02-2006, 01:22 PM   #4
Builder, Remodeler
thill's Avatar
Trade: Builder, Remodeling Contractor
Roof. Definitely.
Make sure to screw all connections before using foil tape. Have a grease fire in the duct, and it may save your bacon.
-TH
thill is offline
Old 10-02-2006, 05:41 PM   #5
ch0mpie's Avatar
done a while ago, but thanks anyway. btw, I always screw my duct work
ch0mpie is offline
Roof vent question. Teetorbilt Roofing 3 03-30-2007 11:52 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
new roof, no vent! Iloveneworleans Roofing 6 04-21-2006 03:24 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
