Ridgid Insulation Under New Siding
Old 12-19-2010, 02:45 PM   #1
peterqbrown
PeterQBrown's Avatar
Trade: Remodeling contractor
This topic has no doubt been discussed, but I am new to contractor talk and cant find it.
I am about to re-side an older home here in Bozeman MT. Wall construction= Asbestos cement shingles (now removed) over 30 lb felt, over 1x6 sheathing on 2x4 walls with fiberglass insulation and plaster board wall covering. This home does NOT have a plastic vapor barrior on the warm side of the wall.
I will be using CertianTeed fiber cement lap siding. I want to add a layer of 1/2" rigid Insulation to minimize thermal bridging and cut down air infiltration. My current insulation choices are 1/2 "closed cell blue (non faced) ridgid insulation or 1/2" foil faced rigid insulation. I dont want to create any condensation problems. foil faced insulation creates a impervious vapor barrior for sure. Anyone want to weigh in on this?
thanks for your time
pb
PeterQBrown is offline
Old 12-19-2010, 04:14 PM   #2
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: Ridgid Insulation Under New Siding
1/2" foam doesnt offer a whole lot for r-value, we use 1" on every house we do the siding on, depending on supplier cost we bounce back and forth between extruded 1" (blue or pink) or enerfoam which is foil backed and faced. i should mention a good portion of the homes we do are reno and fit the same description as yours to a T. we generally use harti so we put on 1x4 for rain screen in the warmer months but switch to 5/4 in the winter just so it doesnt split all to hell when we shoot it on when its frozen.
there are some foams which are perforated but need tyvek over them. if the house is a complete reno, you should talk to the h.o about putting in a venmar it will definitely help with keep the relative humidity down
woodworkbykirk is offline
Old 12-19-2010, 04:21 PM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 90
Good points by Kirk and I agree on the 1" at minimum (2" might be nicer & eliminate your worries about perm ratings, etc...) - as an FYI Venmar equals a brand name ERV / HRV in his neck of the woods
You might also want to check out BuildingScience.com for some wall assembly details that detail best practices in your climate
SLSTech is offline
Old 12-19-2010, 05:49 PM   #4
peterqbrown
Minimum 1" sounds reasonable
1. Are you using the fir strips for a ventilated space or for nailing surface for the siding?
2. Do you have any problems with wavy looking walls?
Old 12-19-2010, 06:01 PM   #5
Sean
SLSTech's Avatar
Rewards Points: 90
Installed properly, you wont as you can fir out the strapping to keep it nice & perfect if there are issues with original building
You could also consider using a cedar breather product to aid in draining / ventilation while either adding insulation &/or keeping depth down
For example 1" foam followed by 1x strapping with foam in between strapping followed with breather
SLSTech is offline
Old 12-19-2010, 06:38 PM   #6
topsail's trimcat
Rewards Points: 384
i should mention the flashing details with this type of rain screen is more diffuicult, we go through vycor by the case doing homes this way. with the wood rain screen we can set our windows into caulking, if the window goes directly onto the foam you cant back caulk as it will eat the foam
Old 12-19-2010, 07:03 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
you could fur out the windows with wood
Tom Struble is offline
Old 12-20-2010, 12:47 AM   #8
peterqbrown
not sure I really understand here. My understanding so far is adding foam of any thickness to the exterior and taping joints against air infiltration essentially seals the walls from passing accumulated cavity moisture to the outside (drying the cavity). Firing strips are a nailing substrate only. leaving the air gap between the fir strips allows air flow and drying should liquid water get past the siding. But I could fill these gaps with foam as well.
My original intention with the 1/2" foam was to impede thermal bridging. I feel confident that we could easily nail through siding and 1/2" foam. I Just looked at this home again this afternoon and going 1" plus furring strips adds a whole host of thickness issues that are deal breakers. It would be wonderfull to add 2" of foam, but realistically thats not feasible without major cost and esthetic problems. It looks like it is 1/2" or nothing. It seems a shame to just re-side with no insulation added, not even 1/2".
Old 12-20-2010, 06:21 AM   #9
Trade: siding
Rewards Points: 20
you can do what you propose,it's in hardies thermal performance technical bulletin
Old 12-20-2010, 06:35 AM   #10
lshomesolutions's Avatar
Rewards Points: 75
I would pull off the 1x6 sheathing. Make sure insulation in the 2x4 cavity is good. 1/2 sheathing ( foil backed), house wrap it , and hardi.
lshomesolutions is offline
Old 12-20-2010, 06:41 AM   #11
Trade: siding
Rewards Points: 20
really? just pull the sheathing?you have no concerns with possible racking?
Old 12-20-2010, 08:37 AM   #12
Sean
SLSTech's Avatar
Rewards Points: 90
First, you need to leave the sheathing & you can also skip the foil backed foam because if you don't have a 1" air gap it isn't going to reflect any radiant heat.
House wrap should be put on the sheathing with cap nailers & taped - then the foam & the seams taped on that.
Then you should either utilize a cedar breather product or furring strips to not only help straighten the wall out but allow any water that gets past the hardi to drain out. That is the best practice - can you get away with out furring strips or cedar product sure, but then you can get water trapped between the foam & hardi product & any gaps not sealed will allow water in
SLSTech is offline
Old 12-20-2010, 09:53 AM   #13
peterqbrown
Thanks guys, this is all great info. I appreciate your time.
Old 12-20-2010, 10:36 AM   #14
Trade: siding
Rewards Points: 20
house that old probably has a few layers of oil based paint pretty much providing an interior vb
Old 12-20-2010, 11:42 AM   #15
peterqbrown
vb? what is that short for?
Old 12-20-2010, 12:18 PM   #16
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Vapor Barrier.
CookeCarpentry is offline
Old 12-20-2010, 01:57 PM   #17
Trade: siding
Rewards Points: 20
check out this faom drainage system,it's only 1/4'' thick but you can install it over foam or sheathing
http://greenguard.pactiv.com/residen...4-drainage-mat
Old 12-20-2010, 03:43 PM   #18
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,463
Ridgid is making insulation now?
Is it as crappy as their tools?
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
woodworkbykirk (12-20-2010)
Old 12-21-2010, 07:45 PM   #19
Theophilus20's Avatar
Rewards Points: 90
^^^ Thats Funny
"I dont Fear Failure, I Fear being Good at Things That Dont Matter"
Theophilus20 is offline
6days to install 24sq of siding dmhes06 General Discussion 26 08-26-2010 08:45 AM
stucco over the existing asbestos siding DLF Builder Business 2 09-21-2009 01:08 PM
Certaineed fiber cement siding strehlow const. General Discussion 17 09-03-2009 07:21 PM
Cement siding install question Adamsbros Windows, Siding and Doors 6 07-10-2009 02:10 AM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 08:40 AM
