Replacing Windows With Brick Exterior
Old 07-19-2008, 11:28 AM   #1
lshomesolutions's Avatar
Never really done this before. Any tricks or Tips?
lshomesolutions is offline
Old 07-19-2008, 11:56 AM   #2
genecarp's Avatar
Re: Replacing Windows With Brick Exterior
dont get a window bigger than the existing opening, whos next?
genecarp is offline
Old 07-19-2008, 05:36 PM   #3
DONOVAN WULF
D MAN's Avatar
Trade: CARPENTRY/REMODELING
is it vinyl, aluminum or wood? remove sashes to make window lighter and easier to handle if you can. if window is typical size, buy a new construction window of same size and remove nailing fin. install just like replacement window by screwing through side. then again, without knowing type of original window, and type of replacement window it is tough to give the correct tips.
D MAN is offline
Old 07-19-2008, 06:30 PM   #4
They are going to be replaced with aluminum windows
Old 07-24-2008, 05:02 PM   #5
President
Jake Stevens's Avatar
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
Measure the RO for the brick taking the old frame out. When you install the windows, pull out old frames, set in the window, drill the brick with a masonry bit to screw the window in the jams. You then can use a backer rod to insulate and seal the outside and install new trim inside as needed. Rock or wood.
Jake Stevens is offline
Old 07-26-2008, 06:01 PM   #6
Big Bob's Avatar
Trade: GBC & Roofing ReM Comm & Res & Insured loss restoration
Hire a sub.... and watch what they do...
to many tips , tricks and triggers...
Big Bob is offline
Old 07-28-2008, 02:19 PM   #7
Jay
JayC's Avatar
Trade: General Contractor (residential & lite commericial)
I did a waranty window replacement on a 25 unit condo retrofit of an old brick ware house in downtown Seattle a few years back. Most of the windows leaked from the original installation. Milgard was the manufacture of the window. The original contractor removed the flanges as per milgards instructions. Although this seems to be common practice (to remove the flanges),on brick installations, I do not recommend this. What I did after consulting with the architect was to narrow and shortin the window R.O. by 3" allowing me to install an inch and half nailer (surround) in the brick opening. This alowed me to retain the flanges of the replacment window. A water proffing consultent was hired. He had me install bitchathane membrane over the flanges onto the brick which was primered first with a bitchathane primer. installing the bitchathane product is a two man job and was the hardest part of this job as the bitchathane and primer installs like contact cement and laminant (no second chance).
This was an expensive solution for Milgard and the original contractor as neither would admit guilt. Both shared in the expence of replacement. It's always cheaper to do it right the first time.
IMHO
Jay
JayC is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
replacing windows in masonry shingler Windows, Siding and Doors 8 03-24-2009 11:48 PM
exterior thin brick pointers? lund6771 Masonry 6 01-09-2008 09:21 PM
brick work on exterior of fireplace qwert General Discussion 12 07-24-2007 06:19 AM
Braking metal for a brick exterior? Luke's Dad Windows, Siding and Doors 8 01-07-2007 06:59 AM
