Replacing Glass Blocks
Old 12-29-2006, 10:04 AM   #1
recruit4meisner's Avatar
Trade: Electrical
I need some good suggestions about replacing a glass block "window" in a master bathroom with something more attractive. I know you guys got me covered!
recruit4meisner is offline
Old 12-29-2006, 01:14 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: Replacing Glass Blocks
What are the requirements; privacy, security, fire exit, airflow/venting, budget, etc? Your profile says "Delray Beach, FL", so you have high temperature, high humidity and possibly salt air if you're close to the ocean. There are many options;
Bronze: great for salt air, high temp and humidity, but expensive.
Fiberglass: great for salt air, high temp and humidity, expensive but not as much as bronze.
Wood: if painted or sealed well not bad in salt air, high temp but humidity can be a problem.
Aluminum: fine for high temp and humidity, but salt air can corrode them.
Steel: about the same as aluminum.
Vinyl: not sure, probably hold up fine with humidity and salt air but I don't how they perform in areas with high heat with lots of UV .
You could always go with a newer, more stylish glass block, cheap option. I'd check with local window distributor and see what they have and recommend.
mickeyco is offline
Old 12-29-2006, 03:08 PM   #3
Teetorbilt's Avatar
Glass block is back. Any pics of your home? Block is the answer if you have an older home or retro-deco.
If it's in a shower stall, you may want to rethink the situation. I'm going the opposite direction in one of my baths, the window is in the stall and leaks from the inside.
Need some info on the house construction. Stick? Block? Cast? How old is the home? Every situation is different and it could be anything in Delray.
Albert Einstein
Teetorbilt is offline
Old 01-08-2007, 02:38 PM   #4
Trade: Electrical
Great info there Mickey, thanks man!
Teetor-Thanks to you as well. Here's some more info:
House was built in '94, CBS, mission style tile roof. I'll snap some pics tonight after work.
Basically, it's a large glass block window in front of a platform tub. Exposed to the road, so yeah, privacy is a concern. "old #2" (as you so graciously say) HATES the block. I could take it or leave it. I've seen some new Pella windows that have interchangable inserts with frosting, or designs inside. Anybody use them yet?
Old 01-10-2007, 08:00 PM   #5
brownie77's Avatar
Trade: Carpentry, Contractor Sales for Pella Window and Door
Its the Pella designer series. There are mulitple types of insert for the window unit. There's a hinged panel on the interior for swaping the inserts in and out. You can also add cordless blinds between the glass to the unit. The blinds come in a varity of colors, and styles. (pleated shades, tilt raise and lower, with a bottom up or top down). These unit are very popular in bathroom applications. Because the blinds are between the glass, it eliminates the need for cleaning, dusting, etc.
brownie77 is offline
Old 01-12-2007, 07:51 PM   #6
tkle's Avatar
Cheap fix,spray 3m adhesive to exterior.It'll give it a glazed look.
tkle is offline
Old 01-12-2007, 08:21 PM   #7
Teetorbilt's Avatar
Other ways to deal with this; Plants, wall with plants inside, shutters inside, other window treatments.
If she REALLY hates THE BLOCK, there is not much that you can do other than replace it with a window, partially block up the opening or totally block the opening.
Why not ask her what SHE would like? When it's done, you're out of the woods!
The wall with plants inside was very popular here in a local DiVosta development.
Why don't you stay inside and have her go outside to see what others see? IMHO, only those into Dali or Picasso would be interested.
Albert Einstein
Building Blocks for Retaining Wall robertc65 Landscaping 2 04-25-2007 03:53 PM
Glass Block Transition Paul_NJ Ceramic & Stone Tile 0 03-15-2007 08:14 AM
Question on Glass Block reusing TurnkeyConst Flooring 0 02-26-2007 10:44 PM
CMU Blocks per man under 'ideal' conditions personalt Masonry 15 07-28-2006 07:06 PM
Broken Sliding glass door sprinklerguy Windows, Siding and Doors 10 01-04-2006 04:58 PM
