Removing Laminate From Countertop
Old 12-02-2005, 08:15 PM   #1
ChuckEA
Guest
ChuckEA's Avatar
Posts: n/a
Is there a way to remove laminate from a partcle board countertop without destroying the laminate sheet? The reason I ask is that I need a small piece for a repair and the only matching material available is from a scrap piece that has already been glued down. I have no idea what type of adhesive was used but was wondering if a heated iron might release it. Appreciate any ideas on this.
Old 12-02-2005, 08:30 PM   #2
Woodcrafter74
Guest
Woodcrafter74's Avatar
Posts: n/a
Re: Removing Laminate From Countertop
I think the iron should work.
Several months ago a reader wrote in to the "This Old House" magazine and had a question about laminate. Apparently they had set a pot that was too warm on the laminate, it heated up the adhesive making it release and then caused a bubble on the countertop. I think Tom Silva's suggestion was to reheat it with an iron (through a towel, so as to not scorch it) and then weight it down.
I would think you could do the reverse; heat it and then try to scrap it loose.
Good luck.
Old 12-02-2005, 08:53 PM   #3
Floorwizard
Guest
Floorwizard's Avatar
Posts: n/a
Ascetone will release it very nicely. Squirt it in there while using a putty knife and it will peel off. It will also go down nice when your all set.
The Following User Says Thank You to For This Useful Post:
Old 12-09-2005, 05:35 PM   #4
Ray R
Guest
Ray R's Avatar
Posts: n/a
I second the acetone. Just be sure not to have the place well ventilated.
Old 12-09-2005, 06:36 PM   #5
Teetorbilt
Guest
Teetorbilt's Avatar
Posts: n/a
Heat will distort the laminate making it useless. Acetone may release it but evaporates very quickly. We have used Tolulene for many decades, Lacquer Thinner works as well. It's a tedious process and only suited to outside as all of the above chemicals are harmful when concentrated and highly explosive.
Another way would be to soak the particle board off. Put the piece somewhere and soak it daily, cover it with plastic between soakings. In a day or so, you should have a bag full of soggy sawdust and some mica that just needs to be buffed off on the backside. This would also be the 'eco' way.
Old 12-10-2005, 02:21 AM   #6
King of Crown
Guest
King of Crown's Avatar
Posts: n/a
yeah......
save some time and money and replace the whole counter top.
Old 12-10-2005, 08:18 PM   #7
Eric K
Guest
Eric K's Avatar
Posts: n/a
everytime i've ever removed laminate whether using heat or thinner, the laminate seems to distort its shape. heat will bubble and curl and when you use thinner the laminate will crack or curl from pulling up. although i've never tryed to reuse a peeled pc.
Old 12-10-2005, 10:32 PM   #8
Floorwizard
Guest
Posts: n/a
I used to work in woodworking.
I cannot count how many times I had to use ascetone to remove a top and reinstall it.
Never had a problem with it, even if it had been on there a week.
It actually can go right back on without reapplying adhesive.
Old 12-17-2005, 12:51 PM   #9
firemike
Guest
firemike's Avatar
Posts: n/a
Acetone works, but watch out for pilot lights on the stove and hotwater heater, or any other device. Been to a few house fires over the years where the home owner or contractor was doing this exact thing and ruined the countertop, along with the kitchen, one even the whole house.
I generally use a heat gun to remove a piece I need to make a patch. Not too hot a setting, and patience is needed. it softens the contact cement up enough to pull apart. Just start at a corner and heat and peel slowly. I use a small (24") wide wrecking bar for easy leverage. Have always had them come up nicely if you don't try to rush or force it.
Old 12-31-2005, 04:11 PM   #10
makfence
Guest
makfence's Avatar
Posts: n/a
Use a little of the glue cleaning solvent in a spray bottle. Start on a corner , lift gentley and spray a little solvent. Have a helper keep lifting and spraying, take a old hand saw and cut the glue strands, while your helper lifts and sprays. I`ve done small counters by myself using that method. IT works great. MAK
Old 01-02-2006, 06:35 PM   #11
J.Wilson
Guest
J.Wilson's Avatar
Posts: n/a
working in a cabinet shop I used to see this all the time, we always used laquer thinner to remove the laminate. Just be patient and dont pull too hard or you'll be replacing the formica
Old 04-10-2010, 01:47 AM   #12
71pontiac
Guest
71pontiac's Avatar
Posts: n/a
Hey fella's, just wanted to let you know that I use a heat gun and it works excellent, just have a little patience if your trying to save any part of it.
Old 04-15-2010, 02:25 PM   #13
Santa's Helpers
Guest
Santa's Helpers's Avatar
Posts: n/a
I use a heat gun and 6 inch putty knife. Do not over heat the laminate and be patient.
Old 04-15-2010, 04:07 PM   #14
BKFranks
Guest
BKFranks's Avatar
Posts: n/a
I have a iron that doesn't get too hot. Apply heat and it usually peals off. I had to do some repairs at Starbucks last week where they had a bunch of delaminating laminate. I bought an extra sheet of laminate, stupid stuff they specify is $6 a sq ft. Pealed off no problem and reused the same stuff and didn't have to use the new. I'll save it for another Starbucks job. Got 6 of those to do next month.
Old 04-16-2010, 12:34 AM   #15
send_it_all
Guest
send_it_all's Avatar
Posts: n/a
Lacquer thinner in a spray bottle. Lift an edge with a putty knife and squirt a stream of thinner under it while sliding the knife under it. It will peel right off.
Old 04-16-2010, 12:43 AM   #16
JumboJack
Guest
JumboJack's Avatar
Posts: n/a
Look who the cat dragged in...
Old 04-16-2010, 10:29 PM   #17
send_it_all
Guest
Posts: n/a
Yeah. He ate me, then coughed me back up with a fur ball, then ate me again.
Old 04-21-2010, 08:34 PM   #18
CARPENTERDON
Guest
CARPENTERDON's Avatar
Posts: n/a
An iron works just fine, but you cannot leave it in one area for too long or the laminate will bubble/distort.
Just like ironing clothing, you must keep moving the iron around the surface. The adhesive will soften and you can remove it.
To re-apply, place the laminate where you want it and heat with the iron. I've done it many times with great success!
Removing a small section of laminate flooring MKamis Flooring 3 07-30-2007 06:02 PM
Best substrate for p-lam countertop C.C.R. General Discussion 4 03-28-2007 09:37 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
Painting Laminate (Formica) Countertop Wild Blue Painting & Finish Work 14 12-01-2006 08:29 AM
Replacing Laminate on Countertop Neil_K Remodeling 8 02-13-2005 11:58 AM
