Remove Chimney
Old 12-10-2009, 11:47 AM   #1
Willyy87
willyy87's Avatar
Trade: ASPHALT MAINTENANCE, SNOW REMOVAL, LANDSCAPING
Remove Chimney
I have a house that has a chimney running straight through the middle of the living room, and kitchen area down to the basement. There is a wood burning fireplace on each floor of this two floor house.
The chimney has cinder blocks in the attic that measure approx. 3' x 5' looking from the top looking down. There is a wood frame built inside the attic that surrounds the cinder blocks of the chimney. How do I tell if this cinder block structure is load bearing? The main load bearing beam of the house runs approx. 5' from the chimney structure.
I want to remove the entire chimney structure from the roof down to the basement. I also will need to try to find out if the main floor is being held up by the fireplace structure in the basement.
I only need help in how to find out if any structural damage could occur if I remove the structure, I have the tools etc. to do the brick demo.
Any help, or suggestions would be appreciated.
Thanks, Willyy87
willyy87 is offline
Old 12-10-2009, 12:05 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Remove Chimney
Slick Willy,
I am not sure how Asphalt Maintenance translates into chimney removal, but by the sounds of your question, not very well. Get a professional involved like a structural engineer and make sure no one gets hurt.
Let me also suggest you introduce yourself and give us a little information about the background of your company and projects completed. You will find that you get a lot more intelligent responses.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 12-10-2009, 12:48 PM   #3
genecarp's Avatar
Rewards Points: 2,000
Re: Remove Chimney
"please complete your profile, and continue to the intro page and tell us a little about yourself and your professional experience, thankyou and welcome to ct "gmod
genecarp is offline
Old 12-10-2009, 03:50 PM   #4
Willyy87
willyy87's Avatar
Re: Remove Chimney
I should have mentioned that I am doing this project at home. This is my chimney.
willyy87 is offline
Old 12-10-2009, 03:51 PM   #5
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Remove Chimney
Price installing a new chimney before you remove that one.
cleveman is offline
Old 12-10-2009, 03:56 PM   #6
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Remove Chimney
He is removing the chimney to gain 15 Sq ft on each level. Not replacing it.
DIY.
Take before and after pics, if the house caves in you will be top nominee for Darwin award.
I doubt it is actually load bearing, but the only way to know is to take a really close look.
D K & Sons
dakzaag is offline
Old 12-10-2009, 05:46 PM   #7
Brickie's Avatar
Trade: One on top of Two
Rewards Points: 570
Re: Remove Chimney
Thanks, Willyy87
Why in the world do you want to remove the fireplaces??
Indiana is a Right To Work State. Proud To Be Non-Union
Brickie is offline
Old 12-10-2009, 06:02 PM   #8
AustinDB's Avatar
Rewards Points: 516
Re: Remove Chimney
silly boy, he is wanting to remove the chimney, not the fireplace
AustinDB is offline
Old 12-10-2009, 08:54 PM   #9
Brickie's Avatar
Rewards Points: 570
Re: Remove Chimney
If it was built properly you certainly would be
Brickie is offline
Old 12-10-2009, 10:02 PM   #10
Willyy87
willyy87's Avatar
Re: Remove Chimney
The Darwin award doesnt sound very prestigious. No, seriously I am planning on removing the chimney and the fireplaces and all related structures from above the roof line to below the lower floor of my house. This is a big structure gentleman. It goes straight through near center of my kitchen and living room. Each fireplace structure on each floor measures approx. 4' x 10'. The main floor has moss rock, and the basement has red brick. The attic has a 3' x 5' cinder block main structure which contains the chimneys (2) running through it.
I want to remove all of it to gain approx. 160 sf of space in my house.
I have a beautiful mountain view that is being blocked by moss rock road block. The guy who built this was nuts!!!! The designers in the late 70's must have not liked open floor plans!
willyy87 is offline
Old 12-10-2009, 10:10 PM   #11
Willyy87
willyy87's Avatar
Re: Remove Chimney
F.Y.I. I have an awsome coal stoker furnace in my basement and these fireplaces have no real purpose, other than satisfying some sick mans need for big fireplaces. They are simply blocking my awsome views of the Big Horn Mountains and my yard!
willyy87 is offline
Old 12-10-2009, 10:32 PM   #12
Aframe's Avatar
Trade: Carpenter/GC
Rewards Points: 550
Re: Remove Chimney
Separate chimney for the furnace, right? or are you replacing with a smaller chimney?
If you are unable to determine yourself if it is a supportive chimney, you need to have someone with framing/building experience with you as the chimney is removed, to evaluate and build in necessary temp supports.
Unless you open up walls and ceiling around the chimney first, a structural engineer would only be able to give you a guess. Probably a long shot, but are there copies of building plans available through your building dept?
If it it a structural chimney, you may, (depending where you live) need an engineer to design structural replacement.
Aframe is offline
Old 12-10-2009, 10:42 PM   #13
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,878
Re: Remove Chimney
Willy -
Have a professional look at the house. Modern codes do not allow a fireplace to be a structural element, but there are exceptions.
Years ago, many homes were traditionally built with a large chimney serving many different uses, but they were the "core" of the home and provide immense stability in addition to carrying vertical loads.
Your home could fall into that category.
Dick
concretemasonry is online now
The Following User Says Thank You to concretemasonry For This Useful Post:
willyy87 (12-11-2009)
Old 12-10-2009, 11:09 PM   #14
Brickie's Avatar
Rewards Points: 570
Re: Remove Chimney
Originally Posted by concretemasonry View Post
Willy -
I agree. He has stacked fireplaces. That's a lot of weight. I would keep a close eye on the reinforced hearth bases and the floors on each level.
Brickie is offline
The Following User Says Thank You to Brickie For This Useful Post:
Old 12-11-2009, 06:51 PM   #15
Willyy87
willyy87's Avatar
Re: Remove Chimney
This house was built in 1977. It doesnt appear that the joists are embedded into the cinder blocks in my attic. I belive that this means that the fireplace structure isnt load bearing at least for the cieling portion of the main floor????
As far as the portion below the main floor I am not sure. My neighbor is a recently retired building contractor. I may ask his opinion.
willyy87 is offline
Old 01-12-2010, 09:25 PM   #16
Willyy87
willyy87's Avatar
Re: Remove Chimney
I started the project two days ago. I have removed eight feet of structure from three feet above the roof, down to the ceiling of the main floor. I will now tackle the fireplace structure on the main floor. It measures 3' w x 8' t x 10' L. After that I will tackle the basement. Pretty easy so far!
willyy87 is offline
Old 01-12-2010, 09:47 PM   #17
gallerytungsten's Avatar
Trade: Design
Rewards Points: 250
Re: Remove Chimney
Let us know the end results!
gallerytungsten is offline
crazy chimney idea? Michaeljp86 General Discussion 5 10-01-2009 10:19 AM
Clearance problem for chimney GregWCIL Masonry 3 07-07-2009 10:54 PM
Suggestions on supporting chimney in attic? John Andrews Masonry 6 06-10-2009 08:47 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 09:35 PM
Metal chimney replacement trade Construction 5 04-06-2009 01:35 PM
