Trade: General Contractor, Whisper Creek Log Home dealer
Remod Questions
I am currently in the process of remodeling a 1 bedroom house. I am redoing all of the flooring, walls, cabinets etc...
Question 1: I am putting laminate flooring in the kitchen, living and hallways. Since it is a floating floor, do you put the cabinets in first and then butt the flooring up to it? What do you do around the washer and dryer? under the stove, dishwasher and fridge? Question 2: I removed all of the baseboard heating unites (excluding the plumbing). What is the easiest way of putting it all back in. I have never dealt with that stuff and it was a pain in the you know what to get out so I am assuming it is going to be worse putting back in. Any tips? Question 3: Tile under the bathroom vanity? Around the toilet or under? |
#2 | |||
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Remod QuestionsQuote:
Re: Remod Questions
Ok so butt up to the cabinets but under everything else?
#4 | |
Class A Contractor "BLD"
Trade: Remodeling and home improvements
Looks like some pros were here. |
Finish Carpenter
Trade: Finish Carpentry
Re: Remod Questions
Butt to cabinets. Under everything else. Tile under everything if you can. (less cutting) Never ever tile around a toilet.
Question # 2 I don't have a clue. Thats why there are plumbers and HVAC guys. |
Remodeler
Re: Remod Questions
Just a small point think other posts have covered everything except, where you put laminate near sinks etc anywhere there is water it should be sealed to prevent water getting in and destroying the flooring.
#7 | |
Chief Toilet Mover
Lic. Remodeler/Builder
Trade: Licensed Remodeling/Builder Contractor
Re: Remod Questions
Mike,
It used to be when using snap-lock, glue was used on the top of the toung in the wet areas only to keep out water. (If I remember correctly) Joe. |
Re: Remod Questions
Webs, start with a disclaimer. All of the areas that you mention are susceptible to water damage, you should not be responsible for that.
Recommend buying enough to replace these areas once. I also dam the kitchen to keep water from getting to the rest of the house.
Trade: remodeling/specializing in kitchen & baths
Re: Remod Questions
wilsonart strongly encourges the use of blue fusion in potential wet areas, and will honor their 25 yr warrenty if installed by a certified installer. REMEMBER the 1/4" rule w/ laminate flooring, ignore this and you won't again.
#11 | |
As far as sealing around the wet areas, I have heard that too and plan on doing that. I did all of the demolition this last weekend. I was amazed at how easy popcorn comes off the ceiling when it is sprayed down. Next job is to hang the drywall on the walls. |
Re: Remod Questions
Teetor how do you dam the kitchen from the rest of the house?
Re: Remod Questions
web use spacers @ walls, cabinets, etc. pull the stool, check flange for reinstall, fit flooring around flange, then fill that area w/ silicone. as multi said glue the top tounge and also seal all cut edges w/ same glue as added protection. all laminates come w/ instructions READ CAREFULLY and follow. count on 20% waste
#14 | |
Chief Toilet Mover
unlicensed hack
Trade: wood butcher
Re: Remod Questions
Sometimes I damn the bathroom, at least the toilet once in while when it's plugged..... damn thing.
Re: Remod Questions
is there a spacer that you can buy that goes against the walls and the cabinets?
Re: Remod Questions
To dam the kitch. you need to install a transition. Cut the track accurately and bed in some nasty stuff like 3M 5200. Seal the ends and any joints and install as normal.
It won't stop floods but it will contain the smaller leaks which are more prevalent. I use the system anywhere leaks can occur, baths, utility rooms, etc.
#18 |
Re: Remod Questions
web the spacers can be bought and they are tapered. try wilsonarts website.
| Lots of questions about drywall and bathrooms | nobody | Drywall | 30 | 11-27-2008 01:33 PM |
| A first timer has a few questions (will proabably be long) | Tpointin | Business | 6 | 04-12-2007 09:05 PM |
| I'm new and i have questions... | Jadzu | General Discussion | 2 | 08-25-2006 07:03 AM |
| Qualifing Questions For Customers | dfwhomeremodele | Marketing & Sales | 19 | 03-22-2006 01:15 PM |
