Quick Question About Electric Baseboards And Moving Them
Old 04-11-2006, 07:23 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Looking at a project where there is an existing baseboard heater running right up against the current shower. The project will call for expanding the shower so the heater will end up in the way.
Is the fix as simple as just replacing the existing baseboard with another smaller unit?
Mike Finley is offline
Old 04-11-2006, 08:25 PM   #2
Tom R's Avatar
Re: Quick Question About Electric Baseboards And Moving Them
Should be as simple as 'that', - - long as the electric comes in at that 'opposite' end, - - which I'm sure it does.
http://www.tr-built.com
Tom R is online now
Old 04-11-2006, 08:25 PM   #3
Electrical & Plumbing
Atricaudatus's Avatar
Trade: Electrical and Plumbing contracting
Mike, it should be just that simple. Just keep in mind that the length of the heater is usually related to its wattage. So, a shorter heater will put out slightly less heat.
Another alternative would be to install a wall mount fan forced heater.
-Rhett
Licensed electrician and plumber
Atricaudatus is offline
Old 04-11-2006, 08:31 PM   #4
Chief Toilet Mover
Thanks guys.
I was thinking about changing it out to one of those Cadet electric registers...
But that might be really opening a can of worms since I am guessing that the current base board heater turns on and off based on the whole house thermostat. It would be nice to convert this one to it's own programmable thermostat mounted only in the bathroom, but I don't see how that would work since the current electric baseboard heater would only be getting voltage when the rest of them are being turned on by the main house thermostat.
Old 04-11-2006, 10:19 PM   #5
747's Avatar
why not try talking them into a new tile floor. Then you could go with electric radiant floor heat underneath.
747 is offline
Old 04-11-2006, 11:09 PM   #6
Chief Toilet Mover
Actually that is already part of the deal, but I wouldn't trust an electric under tile heat mat to be the sole heating source of the room. I consider them supplementary and mostly more of a comfort or convenience type of product.
Old 04-12-2006, 10:49 AM   #7
...I am guessing that the current base board heater turns on and off based on the whole house thermostat.
Mike,
That would be a pretty unusual installation in my experience. Most of the baseboard heated homes I've encountered have a separate, line-voltage t-stat for each room, either on the the wall or on the heater itself; especially bathrooms. The ability to independantly control the temp in each room was one of the few advantages to using BB heat (sort of a "zoned" concept) since electric resistive heating is notoriously energy hungry.
Look for a line voltage dial type t stat on the wall or a knob on the end of the heater. If this unit really is controlled from a central whole house t stat, I would give serious consideration to separating it from the others and putting it on its own control.
I'm curious about this one.
-Rhett
Old 04-12-2006, 10:56 AM   #8
That Cadet looks like a good alternative, by the way.
What wattage is it? Is it fan forced?
What size is this bathroom?
-Rhett
Old 04-13-2006, 08:48 AM   #9
DGFVT
CE1's Avatar
Trade: Electrical
Mike
If this is a bathroom remake and the cabintes are going to be replaced you might want to look at a Broan Trimline Kickspace heater. I have used them before and it makes for a nice looking remodel job.
http://www.kitchensource.com/bathroom-fans/br-112.htm
CE1 is offline
Old 04-13-2006, 09:45 AM   #10
Chief Toilet Mover
Originally Posted by Atricaudatus
Mike,
Hey, if that is the case then that's even a better argument for dumping the base board heater in there and going with the Cadet since that would allow it to work off a programmable thermostat. That would free up the wall space and be an upgrade over the baseboard.
These units are available both in 110 and 240 and each unit is also variable on the wattage by what wires you connect, you can make it 500, 1000 or 1500 watts. Fan driven with a squirrel cage type fan. They fit right between 2 studs and you can do a remodel install by just cutting out the opening for the unit and slipping the box in, drive a couple of screws and you're about done. Not counting running the wire if you take more than 20 minutes installing it you're doing something wrong.
Including the additional programable thermo they cost about $225.00 for everything.
The bathroom is about 120 sq ft.
Never installed a kick toe heater yet, they look pretty cool too.
Old 04-13-2006, 10:52 AM   #11
I really like the sound of that Cadet. The versatility and ease of installation make it pretty appealing, and it would easily handle a 120 sg ft bath. I'm going to have to look into those. Thanks Mike!
-Rhett
