Putting In A Skylight
I am a general purpose handyman and have done it all except for installing a skylight. My neighbor wants a V-lux installed and it looks pretty straight forward. I have 24" OC rafters and a very walkable roofline 6/12. The install looks easy enough and I know what I'll have (approx) in materials. What I don't know is what to tell him for labor because I've never done one before.
Anyone with experience putting one in please let me know your thoughts. The skylight and flashing kit is $400.00. The lumber/plywood,etc is approx. $150.00. Misc caulk,nails etc $50.00. The drywall will be about $350.00 -$500.00 per my drywallers word. So that's about $1,100.00 in materials. I was thinking $2,500.00 total would cover everything safely. Sound about right? Thanks. J. |
Re: Putting In A Skylight
welcome , sounds in the ballpark, assuming you dont find any suprises when you open up the cieling, also , watch out for multiple roofs.
Motorboatin' son of a ...
I've put a bunch of v-lux skylights in. Their pretty easy. Cut your opening, install curb, flashing, caulk. There should be some directions in the box in case you have any questions. You should have no problem. $1400, not a bad days work.
#4 | |
Re: Putting In A SkylightQuote:
Funny you should say that. They added on years ago and the new roofline went over the old existing. So I actually have to go through two roofs. I figured I would cut out the outside roofline opening and then find center and plumb down to find center on the interior old roof. How much more would this add to the cost? Thanks! |
Odds are not good that the rafters
will be stacked, and if the original is a truss you do not want to cut that one.
#6 | |
Excellent point. The originals look to be rafters as well. This means more bracing, lumber and labor.......so all in all this really is more of a $4,500.00 job then. |
can not really give you a $, to many variables without seeing house, also we all have different overheads, work at different paces, and require different rates..
Just trying to get a ballpark. Like I said I've done just about everything but just never a skylight so I know I'm able to do it and do it well. Just trying to figure out a fair estimate. Thanks.
I like Green things
Are you going to peel the shingles off around your new hole? Are there multiple layers of shingles, the whole double roof thing is enough to make someone tell the person who wants the sklight that they are crazy. Dunno, I will say the last ones I installed were 2 next to each other and one above. It takes a long time to flash and shingle around skylights. Especially if you do it the right way.
#10 | |
Super B
| Putting green lights | Ironwood Land | Outdoor Lighting | 3 | 02-15-2008 07:35 AM |
| What is the lowest pitch roof everyone is comfortable with putting in a skylight? | mikeybobo | Roofing | 10 | 03-03-2007 11:34 AM |
| old skylight on flat roof | wayne3434 | Construction | 1 | 02-12-2007 07:00 PM |
| Skylight leaking | jason97z28 | Roofing | 6 | 01-02-2007 09:03 PM |
| Electrically operable Velux skylight motor size | Brendakeen | Electrical | 12 | 11-28-2006 01:38 AM |
