Proper Way To Handle This...
I am in the process of giving an estimate to turn an unfinished deck into a year 'round sunroom. The folks want heating/air, so the space under the deck will have to be enclosed. Presently, the deck sits on concrete encapsulated pile-ons.
Just wondering about the proper way to handle this. It will be sub-contracted out but would like a little knowledge before I start the process. Thanks... Attachment 1828
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Class A Contractor "BLD"
Trade: Remodeling and home improvements
Re: Proper Way To Handle This...
Call the city inspectors office. They should provide you with general guidelines to get you started. If you are subing the work, you are the general contractor and you should already have a license right? You will want to get all the proper permits so nothing bites you in the a later on.
Looks like some pros were here. |
Trade: Home Improvement contractor
You should also make sure you get the subs insurance certificate. That way you not on the hook for workers comp. payments!!!
After sealing the under side out to the beam use blown in insulation to fill the joist bays and then use batts to fill the cantalever.
Trade: Additions, Dormers, Kitchens, Bathrooms
I'm with Gordo, talk to the city office before you start.
Allstate Construction "Home Remodeling Pros" Allstate Construction-Michigan Home Remodeling |
Trade: General Remodeling
I have to say check with the local inspector as well. I know here they require a full foundation to have a porch enlosed.
http://www.wolffhomerepair.com " Of course I don't look busy, I did it right the first time " |
Electro-Mech. Contr.
Trade: Mechanical Contractor
What do they require there for mobile homes?
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Darn good question. I never asked them that. The porch I am currently building is open because of this rule. When I went for the permit the first question was is it going to be enclosed? I answer no why and that's when they gave me the foundation rule.
Why do you think the darn things blow away in storms they don't ahve foundations only sitting on some blocks
with ground screws![]() I think alot of states have started to require true foundations under them but that is not my field.
| OK Lady! Where's the Handle! | KentWhitten | Off Topic (Non Trade) | 4 | 05-11-2007 09:15 PM |
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
| What type of slope can mini track loaders handle??? | MC Excavating | Excavation & Site Work | 26 | 08-05-2006 09:09 PM |
| Proper Mountain Excavation Outfit | theyachtman | Excavation & Site Work | 6 | 07-02-2006 01:54 PM |
| PROPER Ventilation???? | Starboyz66ftp | Roofing | 6 | 03-11-2006 04:25 PM |
