What stop sign?
Trade: Home Remodel, repair, and maintenance.
Plank Paneling
Has anyone ever put plank paneling on a ceiling?
I want to make a million dollars, and I want to only work one day a week. |
Re: Plank Paneling
Do you mean something like beadboard?
David Davis
Trade: ? No thanks, I like mine better!
Re: Plank Paneling
Wainscoting? Or just planks butted up to one another?
Shed |
Mod / ArchiBuilder
Re: Plank Paneling
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Re: Plank Paneling
Carsiding?
What stop sign?
Re: Plank Paneling
I thought that might happen. I do apologize, was late and just wanted question out there. I have a customer thought bought a bunch of this stuff from HD/Lowes. I'll try my best to describe. Already went to there website and they have
to try to link/post. The tag saysTRIM & SAVE ECONOMY Plank Paneling Solid Pine Narrow V-Groove Then just bullet selling points. The installation instruction are on the back. It says this stuff can be vertical/horizontal/diagonal. It can be nailed or glued. It is basically T&G 8'L X 3 9/16"W X 3/8D. They want a "rustic cabin look" to their house. I thought it would be OK for ceiling. It doesn't weight much. I would nail and glue it on the truss'. Sorry that I do not know the specific name/style of paneling. As always, thanks to everyone for your replies and help.
Re: Plank Paneling
You really need a backer for that. I always run 1/2" plywood behind that stuff when i put it on walls
Re: Plank Paneling
Sounds like some kind of cheap car siding. You can blind nail it by toe nailing right at the base of the tongue. Then the groove of the next piece hides the nails. Stagger your butt joints and it'll look a lot nicer. I scarp the butts to make it look cleaner.
David Davis
Re: Plank Paneling
I don't know if you'd be able to get away with putting it directly to the trusses. It seems to me that drywall would be required.
I have used similar products, only what I used was a bit thinner, and looked like wainscoting. It was on a porch ceiling, so initially I didn't think I would need to use anything behind it. A problem that I discovered with this was that the wood had a good number of knot holes, and this job was in Missouri, where carpenter bees are abundant....So I put plywood up before I attached the panels.
Shed |
Re: Plank Paneling
I think it will work fine directly on trusses. I wouldn't glue it, just blind nail. If someone wants to take it down later, glue would make it tough. The nails will hold fine.
Re: Plank Paneling
Sorry, I assumed it was existing with drywall in place. (ass-u-me,again) I'd NEVER use 3/8 car siding for ceiling without drywall, unless its a screened porch. I'm sure that violates any code requirement, as well as common sense. Drywall doesn't have to be finished just tape and bed.
David Davis
Re: Plank Paneling
Would be a firebox unless there was some drywall there to slow a fire down. I don't know, maybe it's not an issue, I never knew much about drywall codes. Plus, any knotholes would allow blown in insulation to fall through, if blown insulation is what you are going with.
Shed |
| Hardie Plank (per square rate of installation) | jimetime | Windows, Siding and Doors | 44 | 05-14-2011 03:18 PM |
| Installing Hardi Plank Siding around windows w/ J channel | brownie77 | Windows, Siding and Doors | 8 | 11-21-2007 08:52 AM |
| Painting paneling | house bldr | Painting & Finish Work | 8 | 10-04-2007 08:45 AM |
| paper over paneling | Joewho | Painting & Finish Work | 8 | 04-29-2007 05:35 PM |
| wood paneling question guys | bigbrew | Painting & Finish Work | 11 | 01-14-2007 10:26 AM |
