Patio Door Inside Glass Broken, Outside Glass Fine...
Old 01-27-2017, 11:26 AM   #1
ZDriver's Avatar
Rewards Points: 2
How the heck did this happen?
Never seen this before.
The homeowner is thinking because the vent is right there it was the temperature outside being cold, and heat hitting it directly from the vent that caused the shatter.
Seen this? Heard about this?
6 year old builders grade door, checked for manufacturer, no sticker
Patio door inside glass broken, outside glass fine...-resized_20170126_113044.jpg
ZDriver is offline
Old 01-27-2017, 11:40 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 652
Re: Patio Door Inside Glass Broken, Outside Glass Fine...
Yep. As long as the glass surface is in great shape, it can take a lot of thermal stress. But if it gets one little dink or scratch, all bets are off.
The longer it's been there, the more likely it got bonked. Could have happened a year ago, and just now let loose.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
DaVinciRemodel (01-30-2017), SmallTownGuy (01-27-2017), Tom Struble (01-31-2017)
Old 01-27-2017, 11:42 AM   #3
Bull Trout's Avatar
Rewards Points: 186
Probably not heat that caused it to break initially, likely a ding and then the heat, also not all that uncommon for one of the two panes to break
Bull Trout is offline
Old 01-30-2017, 05:35 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,970
I had one happen to me years ago in the townhouse I was living in.
It was summer though. The A.C was turned way down ...as in cold inside and it was brutally hot outside.
I initially thought an irate husband put a bullet through it.
Robie is online now
Old 01-30-2017, 09:03 PM   #5
Lettusbee's Avatar
Rewards Points: 1,596
If someone puts an applied film on the glass, to reduce the solar gain, that will void the manufacturer's warranty.
I've been told that it can cause glass breakage. Usually it's just a seal failure though.
Lettusbee is offline
Old 02-04-2017, 06:33 AM   #6
builditguy's Avatar
Rewards Points: 120
I noticed my comments had disappeared. At first I thought I must have put in something that was offensive. Didn't know what, but I must have, or it wouldn't have been deleted. Since I see the same thing above, that probably wasn't the case. Must have just been computer issues. Or, of course the Russians deleted my post. Either way, I'll put it back up and see if it sticks.
First, I can't stand the term, "builders grade." I'm sure most builders would agree. Most of us use the best quality materials possible. I never want to go back on a job and say, "I can't imagine what went wrong, we used the cheapest products available." Sorry, had to get that out of my system.
I've seen 2 like this. Both about 20 years old, same house, a few years apart. It happened in the middle of the night. The homeowner said it was a loud pop and they thought someone had shot through the window.
Just like the other posters. It happens from time to time.
Maybe the term "Do it yourself grade." That seems more appropriate.
builditguy is offline
Worth It? Bosch 1640VS (Fine Cut Power saw) David7586 Tools & Equipment 34 03-05-2017 09:03 PM
Boom goes the...Shower glass TNTSERVICES General Discussion 161 02-12-2015 12:15 AM
Crushed glass fillers, ? Dyer Sandblasting 19 03-22-2013 10:44 AM
Old Glass Door Knob - Conversion Kits? Chopsaw Chick Remodeling 8 01-12-2013 10:32 AM
Broken Sliding glass door sprinklerguy Windows, Siding and Doors 10 01-04-2006 04:58 PM
