Originally Posted by JonM
All the surfaces exposed inside the garage needs to be 5/8" fire rated gypsum board...any doors needs to be rated for 20 minutes.
If the roof line is exposed inside the garage then that needs to be covered also
Actually, isn't a 1 hour rating required, and that is two layers of 5/8 x rock? the two layers can be on one side, and staggered seams. if you have screw inspections where you are, you will have to have each layer inspected, one before the second layer is hung, the second before mud and tape. the door can be 20 min, but the walls min 1 hour.
