New Cabinet Hinges - Remodeling - Contractor Talk
New Cabinet Hinges
Old 05-19-2005, 09:14 PM   #1
sandtoys's Avatar
New Cabinet Hinges
On the new less expensive cabinet hinges. The hinge pins (one top,one bottom) are threaded but have no point to use a screwdriver on top. The pins work their way loose and fall out!! Please help me with this dilemma..
Thank you,
Rick
sandtoys is offline
Old 05-28-2005, 07:48 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 7,061
Re: New Cabinet Hinges
Loc-tite (green)
Leo G is online now
Old 05-28-2005, 08:32 PM   #3
Teetorbilt's Avatar
Rewards Points: 2,000
I prefer LocTite 271 (red). Apply with a saturated Q-Tip. Hit it a couple of times within 10 mins. Green is for bearings on shafts. Want more details on LocTite? I attend a couple of seminars a year and have current books on file. Great products!
Albert Einstein
Teetorbilt is offline
Old 05-29-2005, 01:25 PM   #4
LRG WoodCrafting
Leo G's Avatar
Sorry Teetorbilt , I was using the Permatex brand. The green version is penetrating so you don't have to take things apart. Just apply it to the joint between the pin and the barrel and it will seep in and lock it for you. The green is also one of their weaker strengths so you can get it off easier than you would with the red loctite, if you need to service the door in the future.
Leo G is online now
Old 05-29-2005, 08:45 PM   #5
Teetorbilt's Avatar
Leo, your type just got very small, hard for these old eyes to read. IMHO the 271 is over-rated. I've been using it exclusively for 15 yrs. and never had a problem breaking the bond. It will penetrate as well, maybe just not as far up the threads. A touch of heat, such as from a soldering iron, destroys the bond. Loctite aquired Permatex in 1972. All same salt, more better.
Albert Einstein
Old 05-30-2005, 10:24 AM   #6
sandtoys's Avatar
I figured some Loctite would be great for keeping the hinge pins in, however I'm not sure how to get the pins back in the hinge? Do you have to take the hinge off (apart).....Not done this before and looking for help.
sandtoys is offline
cabinet hinges neolitic Finish Carpentry 6 06-13-2012 06:53 PM
commercial door hinges rservices Windows, Siding and Doors 4 12-02-2006 12:46 PM
Weird question about euro hinges karma_carpentry Finish Carpentry 12 08-12-2006 04:13 PM
Cheaper source for good brass knife hinges ? karma_carpentry Finish Carpentry 3 12-17-2005 10:15 AM
new cabinet hinges sandtoys Remodeling 0 05-19-2005 09:15 PM
