New Bathroom - Page 2 - Remodeling - Contractor Talk
New Bathroom
Old 10-11-2017, 11:09 PM   #21
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,222
Re: New Bathroom
Yes it was. I normally use a sub for shower glass but my buddy ordered it from Amazon and asked me to install it. Went in pretty smooth.
Sent from my SM-T310 using Tapatalk
overanalyze is online now
Old 10-11-2017, 11:23 PM   #22
Renaissance Man
superseal's Avatar
Rewards Points: 5,630
Re: New Bathroom
Cool, I'm going to pick your brain on a few things...not now, it's getting kinda late.
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
overanalyze (10-12-2017)
Old 10-12-2017, 11:00 AM   #23
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,300
Re: New Bathroom
Originally Posted by superseal View Post
It definitely is, did you use the Enigma X?
How do you address out of plumb walls?
Big Johnson is online now
Old 10-12-2017, 12:26 PM   #24
Always Learning
Re: New Bathroom
Shot you a PM with my number if you have a question.
superseal (10-12-2017)
Old 10-12-2017, 06:55 PM   #25
Renaissance Man
superseal's Avatar
Re: New Bathroom
This door does not accommodate or allow for adjustment out of plumb walls...or so the instructions say.
Old 10-12-2017, 06:58 PM   #26
Always Learning
Re: New Bathroom
There is a tiny bit of adjustment but not much. The rollers are on a cam that allows for some up and down of the slider.
Old 10-12-2017, 06:58 PM   #27
Always Learning
Re: New Bathroom
Flat walls are more important!
Old 10-12-2017, 07:44 PM   #28
Re: New Bathroom
My only point is that by hiring a professional glass guy, he can accommodate out of plumb walls that you might not see until you have a square and plumb glass door roll up to it.
Old 10-12-2017, 10:11 PM   #29
tjbnwi's Avatar
Rewards Points: 5,402
Re: New Bathroom
Fix them before the wall covering go on.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
Kumpel (11-07-2017), TBM (12-13-2017), TNTSERVICES (10-12-2017)
Old 10-13-2017, 05:52 AM   #30
Kitchen Cabinets and Tile
HomeArt's Avatar
Trade: Kitchen Cabinets, Countertops, Tile
Rewards Points: 80
Re: New Bathroom
Wow, the shower floor tile looks amazing. Great job!
HomeArt is offline
Old 10-20-2017, 11:42 PM   #31
Renaissance Man
superseal's Avatar
Re: New Bathroom
Linen cabinet came in so I was able install that, the new set of Dreamline doors should be in any day now, wall paper removal, wall and ceiling repairs, primer and paint, new marble window sill, moving a light box, new light bar, door and crown moldings, cabinet pulls, repainting a Nutone vent grill and a bunch of other little odds and ends to wrap this up.
I should be mostly done tomorrow, I've got some sealant work and final paint to do before I put things back together.
New bathroom-img_1291.jpg   New bathroom-img_1292.jpg   New bathroom-img_1293.jpg   New bathroom-img_1298.jpg   New bathroom-img_1327.jpg
New bathroom-img_1336.jpg   New bathroom-img_1338.jpg   New bathroom-img_3946.jpg   New bathroom-img_1317.jpg   New bathroom-img_1324.jpg
The Following 3 Users Say Thank You to superseal For This Useful Post:
asevereid (10-21-2017), KAP (12-09-2017), overanalyze (10-25-2017)
Old 10-20-2017, 11:53 PM   #32
Renaissance Man
superseal's Avatar
Re: New Bathroom
cont...
New bathroom-img_1344.jpg   New bathroom-img_1351.jpg   New bathroom-img_1355.jpg   New bathroom-img_1356.jpg   New bathroom-img_1357.jpg
New bathroom-img_1358.jpg   New bathroom-img_3961.jpg   New bathroom-img_3962.jpg   New bathroom-img_3963.jpg   New bathroom-img_3965.jpg
Martin K (12-18-2017)
Old 10-25-2017, 08:15 PM   #33
Renaissance Man
superseal's Avatar
Re: New Bathroom
I being promised a Friday delivery of the new Dreamline enigma X shower doors to replace the wrong unit the customer originally bought...other than that, everything else is pretty much done.
Light globes are in, corner shelf was refinished in Kona stain to match moldings, vanity top, floor perimeter, inside tile corners and all moldings were caulked, exhaust fan grill was sanded and epoxy coated to match ceiling, cabinet shelves are in, toilet paper holder and robe hook were drilled and secured, door handle was retrofitted with a flat handle for cabinet drawer clearance and a new shower arm extension was sources out and installed to replace the original one which turned out not sufficient for a 16" rain once filled with water...(after 2 days, it developed a leak at a factory adjustable joint which seemed to be pulling apart) That got trashed and I removed the 45deg. shower arm which got replaced with a 4" chrome nipple. The new extension is much heavier and slightly longer which brings the rain head out in perfect proportion to the shower.
After having been on hold for so long on this bathroom, the customer is really excited to bust loose and start using it...i don't blame him, it turned out pretty nice.
New bathroom-img_3932.jpg   New bathroom-img_3933.jpg   New bathroom-img_3953.jpg   New bathroom-img_3981.jpg   New bathroom-img_1375.jpg
New bathroom-img_3985.jpg   New bathroom-img_3987.jpg   New bathroom-img_1387.jpg   New bathroom-img_1398.jpg   New bathroom-img_1257.jpg
The Following 2 Users Say Thank You to superseal For This Useful Post:
Old 10-25-2017, 08:28 PM   #34
Renaissance Man
superseal's Avatar
Re: New Bathroom
cont...Also changed out the toilet, valve and supply hose on another bathroom here as well...another Kohler San Souci piston flush. In case anyone is interested in that shower arm extension, that's a Vida Alegria "REACH" solid brass, high flow...it's nice quality for $50.00
New bathroom-img_1405.jpg   New bathroom-img_1410.jpg   New bathroom-img_1411.jpg   New bathroom-img_1412a.jpg   New bathroom-img_1413.jpg
New bathroom-img_1414.jpg   New bathroom-img_1421.jpg   New bathroom-img_1423.jpg   New bathroom-img_1393.jpg   New bathroom-img_3991.jpg
Old 11-02-2017, 06:42 PM   #35
Renaissance Man
superseal's Avatar
Re: New Bathroom
The new shower doors finally arrived or should I say I had to go pick them up and I scheduled the install for yesterday. A shout to our forum member Andrew/Overanalyze for offering up his insights and giving me his number in case I ran into any issues.
Before I bugged him, I wanted to go over the specs of the new door given the other door was ordered over a year ago...and yes, some parts have changed and the instructions varied from the previous ones.
No matter, I took it slow and steady and still knocked it out like the pro I am
With hindsight now provided, our tiles walls were within stabila bubble lines, but were a total of 1/4" out of plumb...about an 1/8" per side. The threshold was dead on and slightly pitched towards the shower as should be. The adjustable cams surely came in handy to tweek us were we had to be and like Andrew said, flat is more important.
I would grade the install a success in form and function as every spec was followed to a tee right on down to loctite thread locker on all set screws.
In conclusion, I would say these doors do have some minor adjustability...quite to the contrary of what they lead you to believe, but i'm pretty sure we were close to the limit.
Owner wanted to jump right in and take a shower I told him he had to wait 24hrs. for the sealant to cure
New bathroom-img_4042.jpg   New bathroom-img_4045.jpg   New bathroom-img_1533.jpg   New bathroom-img_1534.jpg   New bathroom-img_1535.jpg
New bathroom-img_1537.jpg   New bathroom-img_1539.jpg   New bathroom-img_1545.jpg   New bathroom-img_1546.jpg   New bathroom-img_1554.jpg
AustinDB (11-07-2017), jlhaslip (11-02-2017), tgeb (11-03-2017)
Old 11-07-2017, 11:45 AM   #36
KitchenAndBath's Avatar
Trade: Kitchen and Bathroom Renovations
Rewards Points: 332
Re: New Bathroom
Agree, I've got few customers choosing this design. And I kinda start liking it too.
Kitchen and Bath | Toronto Kitchen Renovation
5783 Steeles Ave W Toronto, ON M9L 2V1
(416) 744-9111
https://kitchenandbath.ca
KitchenAndBath is offline
Old 12-08-2017, 11:02 PM   #37
Renaissance Man
superseal's Avatar
Re: New Bathroom
I'm back at the bathroom job doing some closet lighting, a towel bar, a custom order mini-blind, hanging pictures all over the house... still waiting on some rubbed bronze light switch covers and another robe hook...and finally a laundry shoot the owner wanted originally when I did the bathroom.
New bathroom-img_4446.jpg   New bathroom-img_4447.jpg   New bathroom-img_4448.jpg   New bathroom-img_4449.jpg   New bathroom-img_4450.jpg
New bathroom-img_4451.jpg   New bathroom-img_4453.jpg   New bathroom-img_4457.jpg   New bathroom-img_4468.jpg   New bathroom-img_4469.jpg
Old 12-08-2017, 11:10 PM   #38
Renaissance Man
superseal's Avatar
Re: New Bathroom
some more...
New bathroom-img_4466a.jpg   New bathroom-img_4464.jpg   New bathroom-img_4478.jpg   New bathroom-img_4480.jpg   New bathroom-img_4481.jpg
New bathroom-img_4485.jpg   New bathroom-img_4487.jpg   New bathroom-img_4488.jpg   New bathroom-img_4497.jpg   New bathroom-img_4498.jpg
Old 12-08-2017, 11:19 PM   #39
Renaissance Man
superseal's Avatar
Re: New Bathroom
I somehow missed removing that nail and sliced it perfectly in half I was wondering what all those sparks were
Landry room is directly below...was planning on dropping linens directly into a 36" wall cabinet above the washer and dryer using 14" ovalated pipe so I can squeeze it into a 12" deep cabinet. Still trying to figure out how I'm going to do the upstairs closet...was thinking about building a box and topping it off with a toilet seat that would be hilarious to see the customers face.
My new Coast headlamp is working out well!
New bathroom-img_4502.jpg   New bathroom-img_4503.jpg   New bathroom-img_4504.jpg   New bathroom-img_4506.jpg
Old 12-09-2017, 02:35 PM   #40
Pangdev's Avatar
Trade: general contractor
Rewards Points: 190
Re: New Bathroom
finish er up
Pangdev is offline
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 12:14 PM
New Bathroom ralph coolong General Discussion 8 06-17-2013 10:58 PM
beadboard wainscotting for bathroom MarkJames Finish Carpentry 10 05-26-2013 06:21 PM
